  • Member For: 13y 8m 7d
problem sorted.... it was the retainer clips on the lifters ... changed them with new ones issues fixed... (chips where loose as )
oh BTW the Oil PSi on cold start was 90-100PSI!
on another note... how do people go around adding OIl Pressure and Temp Sencers on without useing a Plate for the filter....
  • Member For: 12y 5m 4d
u unscrew the stock pressure switch and then screw a 3 way fitting into the block that way you can fit the stock pressure switch and a separate gauge
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 29d
This is a T piece that goes where the oil feed line to the turbo is on the block
Any go fast shop in your area
All senders screw straight in !!
