Poelwyk Member 99 Member For: 13y 8m 7d Gender: Male Location: Werribee,Melbourne, Australia Posted 27/12/12 11:30 AM Author Share Posted 27/12/12 11:30 AM (edited) I had my mate come have a look at it who is a macanic for toll and he thinks my oil pumps not flowing enuf at low revs to loob the rockers and I need a new oil pumpwhat is the oil pressure ment to be on idl for this motor? I have a oil pressure gauge witch is not connected but I will have it connected tomorrow morning to check Edited 27/12/12 11:30 AM by Poelwyk Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341534 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 6d Gender: Male Location: Perth Posted 27/12/12 11:32 AM Share Posted 27/12/12 11:32 AM is your dipstick tube fully seated? did it take 8.5ltrs of oil to fill it? Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341535 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 30d Gender: Male Posted 27/12/12 11:48 AM Share Posted 27/12/12 11:48 AM Mate, get a proper gauge and hook it up. Something is wrong and dont drive it till you find out what it is, otherwise you may stuff your new bottom end.Yes, it sounds like oil pressure not getting to the rockers and that may also mean not getting to the bottom end.Did you touch the head at all after you took it off your old engine?? Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341545 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 4m 21d Gender: Male Location: CQ Posted 27/12/12 11:49 AM Share Posted 27/12/12 11:49 AM Cold start idol I think mine sits around 60psi? When hot it will idol around 35psi? Those are off the top of my head but gives you an idea... Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341546 Share on other sites More sharing options...
Poelwyk Member 99 Member For: 13y 8m 7d Gender: Male Location: Werribee,Melbourne, Australia Posted 27/12/12 11:52 AM Author Share Posted 27/12/12 11:52 AM ill connect the gauge up tomorrow and see what happens...the head was recoed and tested I re assembled the cams and rockers as per ford specs Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341549 Share on other sites More sharing options...
stee3 Member 194 Member For: 13y 10m 4d Posted 27/12/12 11:55 AM Share Posted 27/12/12 11:55 AM (edited) On 27/12/2012 at 11:48 AM, turbotrana said: Mate, get a proper gauge and hook it up. Something is wrong and dont drive it till you find out what it is, otherwise you may stuff your new bottom end.Yes, it sounds like oil pressure not getting to the rockers and that may also mean not getting to the bottom end.Did you touch the head at all after you took it off your old engine??Yer I agree, Did you bleed the lifters after you pulled them out? I wouldnt start it until you put an oil pressure gauge on it and even then prime it before you strart it to see if it builds oil pressure.How long have you run it? it really sounds like the lifters are not bleading up.. Edited 27/12/12 11:56 AM by stee3 Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341552 Share on other sites More sharing options...
Poelwyk Member 99 Member For: 13y 8m 7d Gender: Male Location: Werribee,Melbourne, Australia Posted 27/12/12 11:58 AM Author Share Posted 27/12/12 11:58 AM On 27/12/2012 at 11:55 AM, stee3 said: Yer I agree, Did you bleed the lifters after you pulled them out? I wouldnt start it until you put an oil pressure gauge on it and even then prime it before you strart it to see if it builds oil pressure.How long have you run it? it really sounds like the lifters are not bleading up..yeah ill do that 1st thing tomorrow.... na im in werribee south mate ... Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341553 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 10m 4d Gender: Male Location: south east suburbs Posted 27/12/12 12:14 PM Share Posted 27/12/12 12:14 PM What stee said is also likely happening, these lifters can be a bitch.Check oil pressure and lifter bleed. Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341559 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 6d Gender: Male Location: Perth Posted 27/12/12 12:16 PM Share Posted 27/12/12 12:16 PM On 27/12/2012 at 11:32 AM, Ralph Wiggum said: is your dipstick tube fully seated? did it take 8.5ltrs of oil to fill it?SRS question......did it take a full sumps worth of oil? you want be getting any oil to the top end otherwiseIf it did take a sumps worth, drop 400ml of trans fluid into the oil it will make its way into the lifters and assist in bleeding them. Once they are pumped up drain the oil and flush it with cheap chit and the refill with your oil of choice. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341560 Share on other sites More sharing options...
Poelwyk Member 99 Member For: 13y 8m 7d Gender: Male Location: Werribee,Melbourne, Australia Posted 27/12/12 12:18 PM Author Share Posted 27/12/12 12:18 PM On 27/12/2012 at 12:14 PM, xr6t_ute said: What stee said is also likely happening, these lifters can be a bitch.Check oil pressure and lifter bleed.yeah ill do that tomorrow and see how I go and ill report my findings to you guys ... Link to comment https://www.fordxr6turbo.com/forum/topic/83130-bottom-end-rebuild-help/page/6/#findComment-1341562 Share on other sites More sharing options...
