  • Member For: 13y 8m 7d
ill see how I go and that will work out better for me I can get some money together to get that sorted..
  • Member For: 18y 1m 23d
If that's been honed its interesting that the slugs have been put back in. Givin the crack. The corroded lip uptop, I wouldnt think that's been honed.
  • Member For: 13y 10m 4d
Whast interesting about that picture is you can also see very fine metal in the water jacket just behind that piston. The piston in that stuffed cylinder looks like its been cleaned but look at the crown in the piston behind it. Block also looks like its been decked recently as well. Did you try honing it yourself?
  • Member For: 12y 9m 6d
  On 19/12/2012 at 7:30 AM, ratter said:
We charge a fixed figure for tuning, but any tough up tunes are charged by the hour up to the point of a full tune price
checking and adjusting the tune to the same boost level may only take up to a couple of hours considering compression may be slightly differnt etc, but chasing more power can start to get a little time consuming
hi just wondering what a tidy up tune for a stock ba xr6t would be....no mods juts stock, not chaseing stupoid power just whatevers posible and better econamy price?
cheers
  • Member For: 18y 11m 2d
cheers
the price I mentioned is for cars we have allready tuned, even a basic tune for a car with minimal mods can be time consuming to do 100%
well I have a little update.... the car is all back together with a F6 block... got 2 little issues witch have me a little bit worryed...
1st one
the rockers are Nosie at anything lower then 1500RPM any higher and theres not a sound from them done 20K's in her
2nd one
the car cannot find a happy idl it stalls and carrys on....
but the car drives fine other then them 2 things ..... any ideas on why im haveing the issuses..
the car fires up 1st kick ....aswell
mick when do you guys open back up as I think I realy need to get this in to you
  • Moar Powar Babeh
  • Member For: 19y 7m 6d
are you sure its rockers? Rattly pistons have very similar characteristics, ie noisy below around 1500 and noise disappears under load?
