  • Member For: 18y 11m 2d
yes I would expect those marks to have pretty much gone by now considering the mileage on this car, but do not understand why there is a carbonised piston still in the no 2 bore which also looks like it has been honed
  • Member For: 13y 8m 7d
yeah this had got me clueless too I just dont know what had gone on here it looks like its been honed out not long ago... the car has got 160XXX on it and I havent tutched the motor .... its wired...
but yeah its stuffed
I havent evan pulled it down yet I stoped after seeing this .... mick whats it gonna cost me to get the tune re done after this is re assembled...
  • I <3 Floods
  • Member For: 13y 8m 28d
I find it interesting that you charge your dyno out at an hourly rate mick..
Most mobs I've ever spoken to charge a flat rate.. $X for a tune, $X for a major mods retune, $X for minor mods retune.. Sometimes I wish I lived in victoria..
Then the sun comes out..
mick its just same mods just a retune for the motor..
how long will u think u need the car for ??? would be nice to get a few more Ponys from her ...
Edited by Poelwyk
We charge a fixed figure for tuning, but any tough up tunes are charged by the hour up to the point of a full tune price
checking and adjusting the tune to the same boost level may only take up to a couple of hours considering compression may be slightly differnt etc, but chasing more power can start to get a little time consuming
will I need to run this motor in .... and if so doing so will that do anything to the motor with the tune in it....
and can someone please Tell me Exactly what comes with a Short block...
  • Special needs member.
  • Bronze Donating Members
  • Member For: 14y 7m 23d
Short block is just the bare block with all internal parts but you will need all your externals of your old block (Balancer, Water pump, Pulleys, Flywheel etc.)You may have to swap sumps too (not sure on this) as the BF has an external oil cooler whereas the BA doesn't.
It would be wise to run it in on around 6-8psi for the first 3000k's.
yes you will need to run this engine in and change oil and filter before giving at hard time.
The tune will be fine if you keep it off boost, use the valet tune you were given and that will stop any accidental boosting
ok thanks for that guys ill do that ... mick when can I get it in to you the soonest next year... and what times are you closed over the xmass and new year time
