Cat Stuffed In Ba Xrt
Sard
  • New Member
  • Member For: 16y 2m 17d
Hi guys,
CAT is stuffed in 03 BA XRT.
I need to replace it quick with something as the noise is very annoying.
Current exhaust is original except took out centre muffler.
Figuring I might as well replace everything except dump pipe as it is so old.
What fits on their re later models etc?
I do not want to get a tune - just put on something second hand (stock or similar).
ta.
  • Here since the start...
  • Member For: 21y 8m 16d
You'll have to get another stock dump/cat section from a BA. The later models have a different setup. One off a BF might work, but you'd have to plug up the second O2 sensor port.
Anything from a performance exhaust brand will cause the car to chuck a hissy fit (technical term).
I'm not sure if there's generic direct replacement options available.
  • 3 weeks later...
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 10d
Yes theres heaps u just have to modify it to twin outlet
Aftermarket cat ....... Weld merge section..... Weld twin pipes
Cheers
