  • Member For: 13y 8m 16d
ok guys I cannot for the life of me work out whats wrong.....
I had the top radiator hose chnaged the other day because of a leaking issuse witch is now sorted.....
Steps I take to fill the system
I run the car for about 20 min on idle with the cap off and massargeing the top pipe to help with removeing air.. as I top the system up (no heater on as no Heater core connected)
once that's done that I top the system up and drive it around
The temp sits just a little bit over a quater witch is fine but when I stop the car after a 20 min drive to work and I pop the bonnet and have a look at the level its droped from the max to the low mark and theres coolent all over the Bay from the cap... and you can see its boiled the coolent.... out
I have chnaged the Cap with another Gen Ford cap and its still doing it .. what am I doing wrong or whats wrong....
  • Bronze Donating Members
  • Member For: 13y 9m 11d
May have a cracked head/ leaking head gasket causing combustion gasses to over pressurise cooling system. Needs a TK check to confirm
whats the TK check... but the wired thing is the car drives without a issuse no loss of power nothing... wouldent it be a give away if it had a check or a blown head gasket.. theres no water or anything comeing out the exhaust its idels fine .. I just dont know
  • Moderating Team
  • Member For: 22y 3m 7d
On the old school EF/El's there was a bleeder, you used to unscrew it, that used to let all the excess air escape of the coolant system.
Do these bleeders still exist?
  • Member For: 13y 3m 25d
I had a dodgy thermostat that wasn't opening up and from memory it had similar symptoms to yours and was boiling the coolant bottle out the lid.. Replaced thermostat and has been perfect ever since mate
well I think its a head gasket now as the cap has started to get milky.....
anyone got any ideas on the cost to get it replaced....
