Methanol Injection Into The Turbo Mouth
  • Member For: 14y 2m 10d
Hey guys I done a search but didn't get the results I wanted I want to keep my intake temps down in the staging lanes I'm thinking of a nitrous solinoid or something to inject methanol into the turbo mouth to flick the switch bring the revs up to intake goes down to 25 degrees flick the switch off do a burnout and stage at 25 degrees I'd like to hear what people think.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 14d
This has been covered before
Not a good idea always after the turbo as the delicate blades on the turbo spinning so fast have the chance to be damaged by water droplets hitting them
  • Member For: 17y 2m 21d
Big turbo to squish a whole airport?
  • Like 3
  • Member For: 16y 8m 28d
I think if it's an inside manifold spray and not on intercooler spray it'll be alright down track. I'm also looking at it (just need to save up $$$$$ to get snow performance kit)
  • Member For: 17y 11m 8d
Thanks fellas apreciate the time so before the throttle body is a better idea its just for staging lanes not for use down to strip
Just run a small jet on the water meth kit to suit your current tune, anything upto 375ml. You could potentially go higher but Ive only tested up to the 375ml jet. If you are going fit the kit run it for the whole run. It may not show up on the dyno but should definately help with et and give you a greater safety margin on the tune.
Hey Dan I'm glad there are few racers starting to think heat soak is a major problem in bracket racing I have found leaving with boost has made me do back to back races within a couple of hundredths I wanna try my best to make it even better. And I reckon if you can get intake temps almost dead on everytime your gonna run more consistant numbers and win more races
