JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 27d Gender: Male Location: Adelaide Posted 29/11/12 12:26 AM Share Posted 29/11/12 12:26 AM Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331571 Share on other sites More sharing options...
The Jizard GONE FULL WIZARD Donating Members 1,617 Member For: 16y 5m 20d Gender: Male Location: 720 East Kensington Road Posted 29/11/12 01:24 AM Share Posted 29/11/12 01:24 AM cheers Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331587 Share on other sites More sharing options...
EFSIX I Lead Not Follow... Member 1,026 Member For: 13y 2m 7d Gender: Male Location: Westside,Melbourne Posted 29/11/12 02:50 AM Share Posted 29/11/12 02:50 AM On 28/11/2012 at 6:12 PM, Trent0 said: Hey EFSIX, approx. how much wrap do you use in meters to do the stuff you've done?** also, that link says it's only rated upto 550 C, is that enough?hey buds,ive done so many buds but the last I can remember was headers for a sigma efi turbo? I was running pacemaker extractors and decided to heat wrap them along with my turbo dump pipe..I used up approx 5-7 meters but like I said overlapped the wrap almost half..as for the temp rating being 550'c(1050'F) pretty sure that's ok,ive never had a drama.. I just removed the old wrap off my Expensive Daewoo v8 and slapped them back on my car to see if indeed they'd crack?? took it for test drive and seem to be as good as when I wrapped them,no leaks,crack or any issue at all? I must be one of the lucky ones..lol Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331602 Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 2m 2d Gender: Male Location: Brisbane Posted 29/11/12 04:49 AM Author Share Posted 29/11/12 04:49 AM Ok so heat wrapping may be out the window. Would it be worth ceramic coating a mild steel dump or again is stainless a better option? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331620 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 6m 14d Gender: Male Location: Perth Posted 29/11/12 05:24 AM Share Posted 29/11/12 05:24 AM A quality Ceramic coating is best. Heat wrap will shorten the life of the material beneath. Cast iron tolerates it if the casting is high quality. Mild steel will last for a while and stainless a bit longer. The factory dimpled shields do a good job actually and some of the better high mounts use the same product. If your handy and patient, some brackets and so forth to put the dimpled shields on again is a real good idea.Use what you bought and plan for the next improvement.BTW - for the wiki addicts.... it is not recognised by any credible researchers as a good source. Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331631 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 7m 5d Gender: Male Location: SE Melbourne Posted 29/11/12 05:33 AM Share Posted 29/11/12 05:33 AM On 29/11/2012 at 5:24 AM, BRK said: BTW - for the wiki addicts.... it is not recognised by any credible researchers as a good source.cheers Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331642 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 27d Gender: Male Location: Adelaide Posted 29/11/12 05:35 AM Share Posted 29/11/12 05:35 AM Wikipellor will be up set Cheers 3 Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331643 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 8m 1d Gender: Male Location: Far north queensland Posted 29/11/12 07:48 AM Share Posted 29/11/12 07:48 AM mine is ceramic coated, but still has factory heat shields too Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331683 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 4m 27d Gender: Male Location: Sydney Posted 30/11/12 02:08 AM Share Posted 30/11/12 02:08 AM heat wrapping = looks only Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1331950 Share on other sites More sharing options...
Chaos310 Donating Members 228 Member For: 12y 9m 26d Gender: Male Posted 15/12/12 06:00 AM Share Posted 15/12/12 06:00 AM (edited) HPC in Leongatha are a really good bunch to deal with. They did the piston crowns and skirts in my ducati. including postage to them, it was still cheaper than here in perth. I got quoted around 200-250 to ceramic my dump (4"manta stainless) here in perth.. but I think it will go for a scenic trip to HPC.just my .02ccheers Edited 15/12/12 06:00 AM by Chaos310 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82988-heat-wrapping-exhaust/page/4/#findComment-1337227 Share on other sites More sharing options...
