P1227 Dtc (Wastegate Closed/boost Over Pressure) :( :( :(
gmhkla
  • Member For: 14y 7m 28d
Hmm I'll get it all sussed out on Saturday going to the tuner Saturday morning and spending the day on it till its right... Any more info is great though as I can pass it all on and check it out
Sent from my HTC One XL using Tapatalk 2
ok so had the car tuned again today, improvement in performance again but no go in fixing the issue with the DTC
this guy has tuned HEAPS of BAs BFs n FG turbos and my car is the only one hes had this issue with.
to make the problem even more confusing as soon as the out side air temp drops below 20degrees is when it starts boost cutting and throwing this dtc, when ever its over 20degrees out side I can thrash the sh*t out of it non stop and it wont fricken do it!!
im convinced its a mechanical issue with either the IAT sensor, Wastegate actuator or the Wastegate solenoid.
what do you all think???? :( :( :(
we did data logging today but it was hot outside and the car was running fine, till this afternoon now that the temp has dropped 10degrees its playing up again.
come to think about it the MAP sensor was reading 150kpa lol which worked out to be about 27psi but it was only running on 13
looks like ill be throwing a map sensor in it too :-/
Edited by gmhkla
  • Member For: 18y 7m 10d
You have either 1 of 3 issues or possibly a couple combined
Your tuner does not know what to adjust
The HP does not allow correct turbo control
Your wastegate is not controlling the boost correctly, but either of the above can stop this from setting the code
still believe one of these to be your issue
