harvo Member 50 Member For: 13y 1m 23d Posted 23/11/12 10:15 AM Share Posted 23/11/12 10:15 AM Just thought I'd share my latest project, polished a set of old rims once mexican style (back of car jacked up, in gear) and thought there must be a better way. So after a bit of youtube research and having an old washing machine in the shed already I thought I'd give it a go.Plan was, mount the rim on an old hub on a frame and drive it off the motor with a belt, to easy, wrong. Turns out the old washer has a direct drive motor, no worries......Plan B, cut down washer tubs (inner/outer) mount in frame and build a turntable to mount rims onto. Obviously, still needs some work to level and balance the table (only a mock setup) but this is the basic idea, I'll update this when I get off my ass and do some more work to it.Cheers,DanThe rims I'm polishing Link to comment Share on other sites More sharing options...
cizzink11 Member 352 Member For: 12y 3m 25d Gender: Male Posted 23/11/12 02:12 PM Share Posted 23/11/12 02:12 PM I think the best plan would have been to completely seal the inner basket of te washing machine, if not make it bigger and fill with plastic beads. The friction of the plastic beads would have polished those bad boys nicely. Link to comment Share on other sites More sharing options...
harvo Member 50 Member For: 13y 1m 23d Posted 23/11/12 10:06 PM Author Share Posted 23/11/12 10:06 PM I think the best plan would have been to completely seal the inner basket of te washing machine, if not make it bigger and fill with plastic beads. The friction of the plastic beads would have polished those bad boys nicely.Yeah, I did look into that too (vibratory polishers) but the inner basket was to small to fit them in. Another idea was to mount just the centers on the spindle inside the outer tub, fill with abrasive and run it on a wash cycle ie: cycling back and forth with a compressed air feed into the base to help agitate the abrasive. I've paint stripped on of the centres and they're a fairly rough cast so there going to take some elbow grease to shine up. Link to comment Share on other sites More sharing options...
harvo Member 50 Member For: 13y 1m 23d Posted 21/01/13 06:47 AM Author Share Posted 21/01/13 06:47 AM Well, now I've got RSI in my elbow as well as my wrist but I've also got a mostly shiny wheel to go with it. Needs a bit more work before the final polish and then do it all again x3. Haven't touched the outer rim yet still working on that too.Might even plastidip the lips gloss black?cheers Link to comment Share on other sites More sharing options...
