  • Spooling Member
  • Member For: 13y 4m 19d
Hi guys,
Recently I have noticed that the turbo end of my oil line (earls) is a lot darker and oily colour (obviously).
Is this a problem? Should I have this fixed?
(The rest of the line seems fine, as per pic)
Thanks
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 25d
Its just the heat that's right by the manifold has changed the colour of the braid
  • Like 2
  • Spooling Member
Ahhh that's good.
Thanks for the help boys - makes me feel a lot better!
  • Member For: 15y 2m 19d
I think the cable ties are more a problem they will cook and break reallly soon plus stainless braid will rub through that pipe its cable tied too get some more fire sleeve or use a couple of pclamps so it looks good
  • Member For: 22y 26d
I just cracked up laughing seeing those photos. Yes it is a problem mate. The braided line is not miracle sh-t. It needs to be kept as far away from a heat sources as possible, not as you did it as close as possible to a heat source.
