relentless xr6 Member 363 Member For: 14y 2m 8d Gender: Male Location: Sydney Posted 23/11/12 12:23 AM Share Posted 23/11/12 12:23 AM Hey guys I have a ba xr6t doing 1.560 60 footers I still drive it on the street are there electronic dampening shocks so I can have 90/10 at the track and harder on the street? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5d Gender: Male Location: SW Sydney Posted 23/11/12 12:25 AM Share Posted 23/11/12 12:25 AM Nothing electronic off the shelf, street/drag setup cam be made using Koni yellow struts though. Only downside is taking the coolant overflow bottle off to adjust the drivers side Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 2m 8d Gender: Male Location: Sydney Posted 23/11/12 01:13 AM Author Share Posted 23/11/12 01:13 AM Hey senna thanks for the reply so you think koni give the best of both worlds? Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 2m 8d Gender: Male Location: Sydney Posted 23/11/12 01:14 AM Author Share Posted 23/11/12 01:14 AM Hey senna thanks for the reply so you think koni give the best of both worlds? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5d Gender: Male Location: SW Sydney Posted 23/11/12 01:21 AM Share Posted 23/11/12 01:21 AM The konis will be good, but it will always be a compromise. I would have a complete pair of dedicated 90/10 struts that you could fit up for the drag meets then swap it back out for street duty Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 2m 8d Gender: Male Location: Sydney Posted 23/11/12 01:42 AM Author Share Posted 23/11/12 01:42 AM Not a bad idea senna should only be 2 hour job I'm having throuble transferring weight in my ba ute I was thinking of removing the front sway bar helps transfer some weight I blow the tyree off every run. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5d Gender: Male Location: SW Sydney Posted 23/11/12 01:59 AM Share Posted 23/11/12 01:59 AM Yes, removing the swaybar will help the front lift, but it can make the nose lift unevenly and point you to the wall or centre lineIf you can, leave the rear at standard height so the weight transfer is shared by the front and the rear suspension. If the rear is too low you are asking the rear tyres to hold traction while the front has all the weight on it - usually ends up in smoke Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 2m 8d Gender: Male Location: Sydney Posted 23/11/12 02:49 AM Author Share Posted 23/11/12 02:49 AM My ute is at stock height and has standard rear sport suspension With custom made tramp rods on the spring perch I'm thinking of taking them off because they could be causing the bum of the car to lift up Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5d Gender: Male Location: SW Sydney Posted 23/11/12 03:59 AM Share Posted 23/11/12 03:59 AM If the back end is lifting it means the rods are working well, you just need a set of shocks with rebound to hold the body down and then you need the front end to lift Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 2m 8d Gender: Male Location: Sydney Posted 23/11/12 04:53 AM Author Share Posted 23/11/12 04:53 AM Ok 90/10 front strut and a new standard kyb rear shock what's a good brand 90/10 strut for the front. Link to comment Share on other sites More sharing options...
