  • New Member
  • Member For: 13y 6m 11d
  On 05/01/2013 at 10:30 PM, sct911 said:
:O is it safe to push the stock snail to 325rwkw? If it ever goes bust, pretty sure you've already got all the mods in place and just need to stick in a bigger turbo.
anyone know the max rwkw the twin2.5 xforce can handle?
Yeah mate, Im pushing 330 onmy Fg with 12pd actuator. Ive got a Manta dump and cat with the 2.5 twin xforce cat back and it handles it fine.
  • 11 months later...
  • Member For: 13y 4m 23d
Spiro Autotech Engineering quote for my fg f6
The stage 1 plus kit is a tune using the flash 3 unit and a high flow cat and 4 inch dump pipe. This kit will increase the power up to 330kw. The cost to do the stage 1 plus is $2790.
The stage 2 kit is one of our most popular packages. The stage two kit consists of a cold air intake, 6 x high flow injectors, a full turbo back stainless steel exhaust and custom tuned with the sct flash 3 box. This kit will increase the power to $350 - 360kw. The cost of the Phase 2 kit supplied and fitted is $4995.
The stage 3 kit is a follow on from the stage 2 kit. We add an intercooler and piping kit. A Battery relocation kit. We also move the air intake from the passenger side to the driver's side. We also fit a high flow in tank fuel pump. The last up grade in our stage 3 kit is the removal of the turbo and porting the waste gate port and the replacement of the actuator to a 12psi actuator. The cost to do this is $9830. If you already have the stage 2 kit it will cost $5600 All of the above kits include custom tuning on the dyno with before and after power figures. All of the above kits will improve drive ability, throttle response and in many cases also improve fuel economy depending on driver habit.
We can also go further if you are interested in more power. Please do not hesitate to contact me for further information at your convenience
  • Member For: 17y 1m 8d
  On 05/01/2013 at 9:24 PM, pac23 said:
$6k but you won't make 325 any other way...
cough e85
