ratter Member 6,793 Member For: 18y 10m 17d Gender: Male Location: @ my laptop Posted 10/12/12 05:38 AM Share Posted 10/12/12 05:38 AM On 20/11/2012 at 11:00 AM, Upinder said: I am doing this atm to my g6ethe parts you will need areturbo with exhurst manfoild and dump pipeintake manfioldintercooler and pipesyou can remap your old computer by a person that can tune the carso far I spent about 2 grand on partsand car is going to be done maybe next weekWhat about the turbo ECU, boost controller, MAP sensor, fuel pressure reg, wiring loom etc etc 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82925-fg-xr6-2012-na-help-with-turbo-conversion/page/2/#findComment-1335411 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 17d Gender: Male Location: @ my laptop Posted 10/12/12 05:39 AM Share Posted 10/12/12 05:39 AM On 10/12/2012 at 5:19 AM, revbasher94 said: hey thanks for the replies decided that im going to look at doing minor mods on the na and wait a few years until get enough and get a stock fg turbo and move on from there probably a lot smarter and cheaper and you should be able to get insurance etc 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82925-fg-xr6-2012-na-help-with-turbo-conversion/page/2/#findComment-1335412 Share on other sites More sharing options...
revbasher94 Member 16 Member For: 12y 4m 24d Posted 20/01/14 02:01 AM Author Share Posted 20/01/14 02:01 AM Hey guys it's been a while since I last posted on here just to let ya guys know I bailed fromThe idea of doing the turbo was worried with compression ratio plus it da turbo and all...Got it supercharged instead!!! Hahahah put a vortech supercharger and water to air intercooler kit,Upgraded fuel rail from the typhoon, and a few other bits and pieces alog with fuel pump and etc,Runs at 10psi ATM has the time belt cut to 5000 rpm to avoid detonation until bigger injectors are found which should comeIn the next week hopefully because it's running lean at high revs not enough fuel being squirted into the stock plastic manifold, ATM doing 340 rwhp and peaks at just under 600nm of torque I will put a better post with pics and all later when I have time sometime today,I wanna ask about what u guys know about changing the diff ratio I have the standard diff which has ratio of 2.73:1... It barely accelerates to the potential it has but still flogging Holden's but by not as much as it can do... Can y guys help me out with what to do to change the gear ratios I want to get 3.26 or 3.46 just want much better acceleration I don't care about top end speed Link to comment https://www.fordxr6turbo.com/forum/topic/82925-fg-xr6-2012-na-help-with-turbo-conversion/page/2/#findComment-1451037 Share on other sites More sharing options...
Sooula98 New Member 2 Member For: 6y 4m 12d Posted 01/12/18 12:47 PM Share Posted 01/12/18 12:47 PM How much did that set you back? Link to comment https://www.fordxr6turbo.com/forum/topic/82925-fg-xr6-2012-na-help-with-turbo-conversion/page/2/#findComment-1667637 Share on other sites More sharing options...
