mic Donating Members 1,725 Member For: 17y 3m 26d Gender: Male Posted 01/12/12 06:03 AM Share Posted 01/12/12 06:03 AM maybe crap got through the filter and blocked the injector, causing some pre det there. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1332457 Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 9m 18d Posted 02/12/12 11:10 AM Share Posted 02/12/12 11:10 AM Mate this is excactly wat happened to me. And caused number 1 to look like a piece of spaghetti and piston 3 to touch the valves. I'll see if I can find pics.Sent from my HTC Desire S using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1332847 Share on other sites More sharing options...
SecaBoy Donating Members 203 Member For: 16y 3m 12d Posted 02/12/12 11:36 AM Author Share Posted 02/12/12 11:36 AM Eeekkkk! We indexed all the plugs and I have my fingers crossed. LolSeems to be running fine now but I'm changing at 4-5k rpm max now. And no skids. :( lol Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1332857 Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 9m 18d Posted 02/12/12 12:05 PM Share Posted 02/12/12 12:05 PM Yea mine started mid drag strip. Just lost power, would run fine coasting and cruising but under full load it was good for a few seconds then just like someone had pulled a boost line but still had full boost. Took me a while to find it to. Did an intank pump and everything only to find it was the filter. But I was running a surge also. Sent from my HTC Desire S using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1332867 Share on other sites More sharing options...
F1PERFORMANCE Donating Members 104 Member For: 16y 2m 1d Gender: Male Location: VIC Posted 02/12/12 02:21 PM Share Posted 02/12/12 02:21 PM the piston would have hit the valves if its hit the plug - my thoughts are it has happened from detonation from lean mixture (broken fuel filter) - would get a bore scope down there asap and dont drive it untill you have checked it . 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1332879 Share on other sites More sharing options...
SecaBoy Donating Members 203 Member For: 16y 3m 12d Posted 03/12/12 03:19 AM Author Share Posted 03/12/12 03:19 AM drove it all weekend with no dramas. even in this heat it didnt play up at all. Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1332977 Share on other sites More sharing options...
dustyae86 Member 46 Member For: 13y 7m 8d Posted 03/12/12 07:22 AM Share Posted 03/12/12 07:22 AM We had a bf turbo once that skipped a tooth on one of the cams, car ran like crap all the time, and would make hardly any boost Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1333031 Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 9m 18d Posted 03/12/12 08:24 AM Share Posted 03/12/12 08:24 AM This is what my rod looked like. If you zoom in u can see the piston was actually fouling on the crank. Link to comment https://www.fordxr6turbo.com/forum/topic/82837-flashing-engine-light-fg-falcon/page/3/#findComment-1333048 Share on other sites More sharing options...
