  • Member For: 16y 1m 28d
Warping a cast manifold...... Really ? no fatigue cracks from the around either of the flange's ??? Can you see the deformation by eye ?
  • Donating Member
  • Member For: 18y 6m 10d
You could also bolt your standard manifold down to some thick C-channel and heat it up, let it cool and it should be straight again.
  • Member For: 15y 6m 9d
this plus a damp rag if it doesn't work
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 4d
xyz if u got the low mount sling me a pm so we can talk
yup managed to warp the chit out of the stock cast manifold, had the tractor sound comming from the flange section so I tore it apart and sent it to ATS to have the flanged section faced and the rear housing on the turbo faced aswell but when we put a straight edge on the runners the 3/4 were flat but it bananed out towards strut tower so runner 2/5 were a coupla mm out but 1/6 were close to 7mm out
so in love of the old FT torque method I started by tightening the 1/6 runner and worked in and cranked the chit out of those beaudiful ally threads in the head lol
so far all good but I know if it has to come off again those threads will be cactus
no cracking on the manifold or webbing and the bloke from adelaide turbo services was amazed that they were so warped
  • Member For: 17y 1m 15d
I prefer the look of low mount too. Shows off the design better.
  • Member For: 19y 9m 27d
Here's a low mount, GTX3582r, T4 1.06 rear and 60mm TS gate.
When I can be ar$ed and Wiggum can be ar$ed firing up his TIG again......it might actually get bolted to my $hitbox.
Jet were you running e85 or 98? I'd be curious as to what your timing curve looked like at WOT.
post-6920-0-88731800-1352902887_thumb.jp
Nar it was the e85 @21.9psi
That set up looks horn toads
Yeah a PITA compared to a direct replacement mani. Wiggum was talking about welding up a replacement log style manifold once upon a time. I think snort performance make replacement log style manifolds....but not sure that the design would be better (or stronger) than an FG. The Tunehouse manifold looks horn...bit different design to my low mount.
