nosiriwasnt New Member 4 Member For: 13y 7m 18d Posted 10/11/12 11:56 AM Share Posted 10/11/12 11:56 AM (edited) Hi all, am still uncertain what option to go with for safe fuel supply at only 300rwkw. There is lots of great info on fg fuel surge/cut at under 1/3 tank. Obviously the 044 and swirl is the most common solution although do not want pump noise inside car as I know it will piss me after a while. Can it be heard at idle or above? Love the new KPM intank but for only 300kw seems like major overkill.Does anyone know if installing a walbro or similar intank pump will just improve fuel flow in l/hr or do these pumps sit a little different in tank and not suck air as easily? Im guessing not but worth asking to save a grand.Cheers Edited 10/11/12 11:57 AM by nosiriwasnt Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/ Share on other sites More sharing options...
AirStrike Donating Members 387 Member For: 16y 7m Gender: Male Posted 10/11/12 12:01 PM Share Posted 10/11/12 12:01 PM Can you hear a 044 @ idle, yes. Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323256 Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 1m 28d Gender: Male Location: Brisbane Posted 10/11/12 03:02 PM Share Posted 10/11/12 03:02 PM (edited) In-tank pumps are generally a direct replacement of the standard pump where by it will only Increase LpH. I have a walbro Gss 292 or 294? that is rated to 275/300LpH and I'm running 360rwkw without a problem.A surge tank in any case would be ideal but for a daily driver with the occasional squirt up the road, an in-tank pump will be fine for your fueling requirements.** oh and I can hear my pump on occasion too, especially when it primes before I start the car Edited 10/11/12 03:04 PM by Trent0 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323270 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 28d Gender: Male Location: Far north queensland Posted 10/11/12 07:15 PM Share Posted 10/11/12 07:15 PM Twin 044 on mine, can hear it prime but all good after that, mainly turbo whistle Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323281 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 16d Gender: Male Location: Newcastle Posted 10/11/12 09:31 PM Share Posted 10/11/12 09:31 PM My previous FG ran the factory pump for the 3 years I had it and no issues with surge even when at the track. The swirl pot design is very good at keeping the pump supplied with plenty of fuel. If you want to go to a bigger pump for safety sake then a larger intank is the easiest and still remains legal but wont lessen the possibility of fuel surge if that's what you are concerned about. You'll just be able to supply more fuel to the rail. If you go down the path of a bigger intank then I'd suggest a Walbro 400, which is what I've fitted to my GT. Something you have to be wary of though when installing a big pump is your fuel rail pressure increasing which can increase the amount of fuel your injectors are supplying. You may need to upgrade your fuel reg or adjust your tune.Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323293 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 3d Posted 10/11/12 09:43 PM Share Posted 10/11/12 09:43 PM ^^ this. In terms of price your looking at $150-$200 for a walbro intank plus install, next option would be the KPM 460 module which is $900 plus install (but has anti-surge features) and then you consider surge tank with external pump (044 or the like) or the KPM 1000 module.From the testing mick (ratter) did a couple of months ago it appears that at 300 the stock fg fuel pump can't quite handle it, even though it was a fair upgrade from the B series so I'd say its definitely worth upgrading. Personally I'm going for the KPM 460 module because it'll allow me to easily go e85 with the right injectors and for the extra 40rwkw(ish) you get from e85 alone, for a few hundred more on fuel pump and injectors its worth it. That's something to consider aswell Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323298 Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 8m Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 10/11/12 11:12 PM Share Posted 10/11/12 11:12 PM (edited) To add a some finer points to your question, when choosing a fuel system you should considernoiselegalitySwirl pot incorporated / to supply cool fresh aerated fuel for maximum performance and powermaximum application demand and supply abilty to supply maximum demand at below 100%no surge on maximum acceleration or corneringease of fitmentCorrect fuel system pressuresAbility to run the fuel system correctly at near empty without surge or reduced supplyOEM quality and engineering ( value for money)with many good quality internal and external fuel muddles available you need to consider that by the time that they are fitted do they meet all the above considerations and at what price.KPM have met all these requirements with our complete fuel system packages;our Walbro 460 module package that will happily run your vehicle to 350-400 rwkworour Streetfighter 1000 Module that will run your vehicle up to 1000hpBoth packages meet all our fuel system requirements and work perfectly first time without any further additions to your fuel system. We can also supply the correct KPM550cc / KPM1000cc / KPM2000cc Injectors to complete your entire fuel system.Additionally , both the Walbro 460 and Streetfighter modules work just as happily on a completely standard vehicle without any need for re-tuning.I hope this helps explain and bring to light some further considerations. Edited 10/11/12 11:23 PM by KPM Motorsport 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323313 Share on other sites More sharing options...
GTEXXED Banned Banned 910 Member For: 12y 11m 2d Gender: Male Posted 10/11/12 11:28 PM Share Posted 10/11/12 11:28 PM Free steak knives??? Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323319 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 28d Gender: Male Location: Far north queensland Posted 10/11/12 11:33 PM Share Posted 10/11/12 11:33 PM On 10/11/2012 at 11:12 PM, KPM Motorsport said: Swirl pot incorporated / to supply cool fresh aerated fuel for maximum performance and powerSince when has aeration been a good thing? Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323323 Share on other sites More sharing options...
nosiriwasnt New Member 4 Member For: 13y 7m 18d Posted 10/11/12 11:46 PM Author Share Posted 10/11/12 11:46 PM Thanks for the great replies, Benny I am assuming always maintained 1/2 tank as I like many others have experienced fuel cut prior to finding this info. Since Ratter made it known supply is also marginal (low return flow from rail on his testing) well, get out the wallet.I personally do want my fuel system legal which is why I like the KPM module and somehow missed the KPM460, so this is the type of product I am after.Thanks for the quick and detailed responses. Link to comment https://www.fordxr6turbo.com/forum/topic/82788-fg-fuel-system-upgrade-for-300rwkw/#findComment-1323326 Share on other sites More sharing options...
