Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 8d Gender: Male Location: Perth Posted 10/11/12 02:51 AM Share Posted 10/11/12 02:51 AM Catch Can only went in 5 days ago haha. Might see if theres any kinks in the line pretty sure I made certain there wasn'tStart with the catch can......as I said I could be wrong but I thought the only difference was the compression and exhaust valves....Turbo piston are dish to reduce compression and have a different gudgeon pin to an NA, also to my knowledge Turbo rods have a piston cooling oil jet hole in the rod and NA rods don't. Link to comment https://www.fordxr6turbo.com/forum/topic/82780-ba-engine-heavy-breathing-advice-please/page/2/#findComment-1323113 Share on other sites More sharing options...
JK89 Member 56 Member For: 14y 4m 22d Posted 10/11/12 05:05 AM Author Share Posted 10/11/12 05:05 AM yeah I knew the blocks were the same unsure of internal componants. Makes sense though. I dont think the catch can will be it but will double check the lines going from the catch to the inlet manifold - make sure they arent crimped.but where to after that? Link to comment https://www.fordxr6turbo.com/forum/topic/82780-ba-engine-heavy-breathing-advice-please/page/2/#findComment-1323136 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 11d Gender: Not Telling Posted 10/11/12 07:37 AM Share Posted 10/11/12 07:37 AM My guess is that it is probably running an LPG engine/ bottom end. But as Ralph alluded, do a leakdown test just to see where you are. As you may be have a cracked ring/piston, running such high comp ratio would possibly (more than likely) be causing damage over time. Which has lead you to this point. I also find it interesting that your gearbox is still hanging in there, at your power level.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/82780-ba-engine-heavy-breathing-advice-please/page/2/#findComment-1323173 Share on other sites More sharing options...
JK89 Member 56 Member For: 14y 4m 22d Posted 10/11/12 08:42 AM Author Share Posted 10/11/12 08:42 AM It's a fpv f6 t56 w npc 800hp cushion button clutch Link to comment https://www.fordxr6turbo.com/forum/topic/82780-ba-engine-heavy-breathing-advice-please/page/2/#findComment-1323183 Share on other sites More sharing options...
