  • Member For: 12y 3d
I am buying a GTX 35/82 next month. I already have 330kw so I have fuel pump and injectors and valve springs done. what exactly do I need to do to put it in. 12psi acculator? custom manifold for external gate? ported rear housing? nipple?
  • Member For: 19y 2m 28d
Ported rear housing only if staying internal gate. GTX has 4 inch inlet and I think the hot side outlet is bigger than factory turbo.
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 1m 13d
E9gmaYr.jpg Edited by turboboink
  • in the mid....not the bum like some
  • Member For: 12y 18d
External gate has better boost control especially if using a Synapse 40mm item(has in built boost controller and a dozen settings on the one spring along with no diaphragm to fail)
On the actuator topic my 7psi actuator would hold 20psi plus no worries.
I have gone external gate on mine now and have a template for the rear housing pipe if anyone needs it.
A muffler on the screamer pipe works well also.
Edited by Skids4kids
