  • Member For: 16y 5m 1d
  On 24/04/2013 at 7:24 AM, Ford Freak said:
um ^^^^^^^^^^^^^ ?????????
I put a 12 psi in and run nearly 19 psi all the way through on mine
I didnt say a 12 wouldnt hold 19? I run a 12 and hold 19, general rule of thumb is an actuator is good for double its rating so a 12 is good for 24 and a 15 good for 30ish. A 15 will hold boost slightly better then a 12, but a 12 will work fine too.
  • Member For: 15y 6m 13d
  On 21/01/2013 at 6:15 AM, IH8TOADS said:
<blockquote class='ipsBlockquote'data-author="stevanford" data-cid="1352401" data-time="1358733206"><p>
<br />
Yes they do. Just mention to them that you need the 4 inch silicon hose to fit the bigger inlet.</p></blockquote>
I rang Plazmaman the other day and they had no 'off the shelf product' to adapt a 4" intake to their 4" intake.
I then went to MTQ in Perth and confused them even more. I ended up buying a 4" 45 degree elbow and will simply cut it down and see if I can make it fit.
What exactly have others done, starting with a Plazy 4" intake? If they could supply a ready made silicon hose to replace the 4" to 3" reducer elbow I would have gone down that path!
Rang plaz and said I want an airbox/intake to suit GTX
at my door a few days later
  • Member For: 12y 6m 2d
how hard is it to keep 400rwkw to the ground on the street? how wide do your tyres need to be?
my 245 achilles cant even stop a stock fg from spinning
Edited by sct911
depends on what speed, plenty with the gtx are making 400 - 450 . . . . . . . and turning the tyres at the speed limit.
freaky has 20" wheels on a ute and 440rwkw, he is gunna chit himself the first time it steps out in 4th
  • Member For: 18y 11m 11d
stock FG makes a lot of power early in the rpm range which is why it spins easy, a car with a turbo to make 400+ rwkw will not have this boost at low rpms
  • Member For: 16y 1m 7d
  On 24/04/2013 at 6:54 AM, Bonjaz said:
Most settle for a 12 but how much boost do you want to run? If your gonna run well over 15, say 20ish then just throw the 15 on. They say your supposed to run an actuator that is close to your desired boost
I want to run about 19psi. Sounds like the 12psi actuator is the way to go, I don't want the boost coming on too hard as the car is manual. I want some sort of traction.
Decent tyres make a big difference too. I have had a really good experience with Nitto Invo's, they grip really well and last reasonably well for a performance tyre
  • Member For: 13y 3m 7d
Like I said, I was using the 4 inch turbo side intake on the smaller fg turbo. When I was upgrading to a GTX, I went to Plazmaman and asked for a silicone hose to suit a GTX.
  • FREAKY
  • Member For: 15y 4m 13d
ahh I see
thanks
I havent had traction since 290kw in my ute
if you want grip you guys seriously need to stop buying cheap tyres
