sct911 Member 848 Member For: 12y 5m 15d Gender: Male Posted 16/03/13 04:00 AM Share Posted 16/03/13 04:00 AM On 15/03/2013 at 6:24 AM, Bonjaz said: Around $1000 give or take a few hundred depends on how "built" you want it what kind of $$$ will you have to spend if the shaft lets go and causes havok under the car ? Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1372146 Share on other sites More sharing options...
f6mark Member 2,908 Member For: 14y 2m 7d Gender: Male Posted 16/03/13 08:05 AM Share Posted 16/03/13 08:05 AM On 15/03/2013 at 10:58 PM, J@SNOT said: My fg shaft let go on the dynoI replaced it with a bf xr6 n/a shaft and its lasted this far but its a massive risk really, but it also "felt " thicker and more HD for some crazy reasonoh dear.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1372221 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 4m 13d Gender: Male Location: CQ Posted 16/03/13 08:13 AM Share Posted 16/03/13 08:13 AM On 16/03/2013 at 4:00 AM, sct911 said: what kind of $$$ will you have to spend if the shaft lets go and causes havok under the car ?Stick your head under your car and have a look at what it could flog when doing 200kmph could punctured fuel tank, destroy fuel lines, can slap gearbox/pan in extreme cases they can punch up through the floor into your cab or rip your diff out... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1372224 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 25d Gender: Male Location: @ my laptop Posted 16/03/13 08:31 AM Share Posted 16/03/13 08:31 AM one of my customers was up for over $5000 to repair the damage that occured on his car when the shaft let go 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1372231 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 3m 25d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 16/03/13 10:58 AM Share Posted 16/03/13 10:58 AM I know which one Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1372258 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 9m 27d Gender: Male Location: south east suburbs Posted 16/03/13 01:06 PM Share Posted 16/03/13 01:06 PM My factory one is fine. Delete this comment so it doesn't get used against me later down the track.Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1372280 Share on other sites More sharing options...
fehlbie Donating Members 142 Member For: 16y 20d Posted 24/04/13 06:30 AM Share Posted 24/04/13 06:30 AM What PSI actuators are you guys using. I have both a 15psi and a 12psi. Which one should I use? Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1383520 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 4m 13d Gender: Male Location: CQ Posted 24/04/13 06:54 AM Share Posted 24/04/13 06:54 AM Most settle for a 12 but how much boost do you want to run? If your gonna run well over 15, say 20ish then just throw the 15 on. They say your supposed to run an actuator that is close to your desired boost Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1383523 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 3m 27d Gender: Male Location: Melbourne Posted 24/04/13 07:24 AM Share Posted 24/04/13 07:24 AM um ^^^^^^^^^^^^^ ?????????I put a 12 psi in and run nearly 19 psi all the way through on mine Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1383531 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 4m 30d Gender: Male Location: SE Melbourne Posted 24/04/13 07:32 AM Share Posted 24/04/13 07:32 AM Yeah but minimum boost will be 12. Link to comment https://www.fordxr6turbo.com/forum/topic/82766-gtx-3582r-best-way-to-go/page/20/#findComment-1383535 Share on other sites More sharing options...
