FairlaneG Member 68 Member For: 12y 10m 23d Gender: Male Location: Hervey Bay Posted 12/11/12 02:16 AM Author Share Posted 12/11/12 02:16 AM Yep I reset the codes then took it for a nurse up the rd friday arvo.The only codes that came back rekated to the Sensor.I Might have to go over wiring I think as I had to replace the plug from STD NA to the MAP2 plug (different shape)There are 2 wires that look grey/white ish... I 99.9% positive I reversed this with out fault but Hey.... Couldn't be 2 sure I guess...... Buggers me how to test...Ohm reader , Every wire should read a different ohm or Volt correct? Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/4/#findComment-1323872 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 16d Gender: Male Location: Adelaide Posted 12/11/12 04:11 AM Share Posted 12/11/12 04:11 AM Oh dear Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/4/#findComment-1323939 Share on other sites More sharing options...
FairlaneG Member 68 Member For: 12y 10m 23d Gender: Male Location: Hervey Bay Posted 17/11/12 10:17 AM Author Share Posted 17/11/12 10:17 AM (edited) How are w , hope your weekend is good,I have a problem with my MAP sensor Volt reading. A fault code inspired me to get to the bottom of this. Fault code below :-: P0108 - BARO Sensor : Sensor operating : * VREF shorted to : - VREF should be less :: High Voltage Detected : voltage is greater : VWPR : than 6.0 volts. PID :: : than 5.0 volts (VREF), : * BARO signal shorted : reading is in :: : as a result it failed : to VPWR : frequency :: : above maximum : * Damaged BARO sensor :: : allowable calibrated : * Damaged PCM :: : parameter. :I originally thought MAP2 Sensor but seems they are $150+ dollars I thought I would start with checking Volt readings threw the 4 wires connecting to MAP2 switch.I refereed to Repair manual for STD volt reading for test.When the car is cold it should read 5960 Resistance Ohms & 4.3 Volts.Green wire reads 5.5 VoltsBrown Wire Reads 5.0Grey Wire Reads 2.0Grey Wire Reads 2.2What is causing this , what do I need to inspect next... HelpKind Regards Dan Edited 17/11/12 10:18 AM by FairlaneG Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/4/#findComment-1326584 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 24d Gender: Male Location: Maryborough Qld Posted 25/11/12 02:05 PM Share Posted 25/11/12 02:05 PM theres another tuner in the bay, bradly I think hes name is, down old maryborough road, apparently hes pretty good with what he does. should trie him see what he saysalso change MAP sensor and see what happens. your should have sold car and got a already turbo. less hassle lol Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/4/#findComment-1330074 Share on other sites More sharing options...
