Paulie2256 Donating Members 7,441 Member For: 16y 5m 16d Gender: Male Location: SE Melbourne Posted 09/11/12 04:04 AM Share Posted 09/11/12 04:04 AM Why don't you ask your tuner to sort the fuel pressure out? Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1322826 Share on other sites More sharing options...
FairlaneG Member 68 Member For: 12y 10m 14d Gender: Male Location: Hervey Bay Posted 09/11/12 04:07 AM Author Share Posted 09/11/12 04:07 AM I'm on a budget.... He is on monday.From what I can see on the fuel system he is going to have to engineer a connection to plug in his pressure testing gauge to is this correct or does the B series have a connection somewhere I have overlooked ?? Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1322832 Share on other sites More sharing options...
FairlaneG Member 68 Member For: 12y 10m 14d Gender: Male Location: Hervey Bay Posted 09/11/12 08:09 AM Author Share Posted 09/11/12 08:09 AM Just scanned for error codes & Im just curious if these are serious & what they are & if this has any thing to do with my post ?? I need some serious help here guys.1.) P0108 - BARO Sensor : Sensor operating : * VREF shorted to : - VREF should be less :: High Voltage Detected : voltage is greater : VWPR : than 6.0 volts. PID :: : than 5.0 volts (VREF), : * BARO signal shorted : reading is in :: : as a result it failed : to VPWR : frequency :: : above maximum : * Damaged BARO sensor :: : allowable calibrated : * Damaged PCM :: : parameter. :____________________________________________________________________________________________________2) P0113 - Intake Air : Indicates the sensor : * Open circuit in : - Using signal :: Temperature (IAT) : signal is greater than : harness : simulation, :: Circuit High Input : Self-Test maximum. The : * Sensor signal short : disconnect sensor :: : IAT sensor maximum is : to power : and simulate 1.0V :: : 4.6 volts or -50øC ( : * Damaged sensor : on sensor signal :: : -46øF). : * Improper harness : circuit. Simulated :: : : connection : 1.0V signal and :: : : * Damaged PCM : scan PID voltage :: : : : value should be :: : : : similar. If voltage :: : : : is similar check :: : : : sensor, if voltage :: : : : is not similar :: : : : check related :: : : : circuit and PCM. :____________________________________________________________________________________________________3)P1534 Inertia Switch Activated?????????????????????????4)P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection ???????5)P1900 Output Shaft Speed (OSS) Circuit Intermittent Malfunction6)B1676 Battery Pack Voltage Out Of Range7)B1242 Air Flow Recirculation Door Driver Circuit Failure8)U2197 Network ?????????9)U2196 Network??10)B1250 Air Temperature Internal Sensor Circuit Failure Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1322908 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 11d Gender: Male Location: @ my laptop Posted 09/11/12 08:36 AM Share Posted 09/11/12 08:36 AM please do not take this as being rude, but you need to get somebody to sort out this car properly, guessing is going to cost you a lot more than getting it diagnosed correctly.You need someone with some knowledge of these cars to go over the install etc 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1322917 Share on other sites More sharing options...
FairlaneG Member 68 Member For: 12y 10m 14d Gender: Male Location: Hervey Bay Posted 09/11/12 08:45 AM Author Share Posted 09/11/12 08:45 AM any suggestions in SE Queensland Ratter ?& thanks again , Appreciate it. Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1322922 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 11d Gender: Male Location: @ my laptop Posted 09/11/12 08:53 AM Share Posted 09/11/12 08:53 AM Sorry mate, not sure who is around your area, I know Elite are in Archerfield but not sure how close that is to you, possibly narrow your location down a little and some other members in your area may be able to suggest somebody to go over you car and/or tune it once all the bugs are sorted.Fact is your car may be running lean just because of the tune, but without data anyone is guessing Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1322924 Share on other sites More sharing options...
FairlaneG Member 68 Member For: 12y 10m 14d Gender: Male Location: Hervey Bay Posted 09/11/12 10:33 AM Author Share Posted 09/11/12 10:33 AM Hervey Bay QLD Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1322961 Share on other sites More sharing options...
FairlaneG Member 68 Member For: 12y 10m 14d Gender: Male Location: Hervey Bay Posted 11/11/12 11:34 PM Author Share Posted 11/11/12 11:34 PM ran a test of codes. codes say MAP2 sensor.maybe the MAP2 sensor is faulty. I Have my eyes on an original one. Will replace & check.Let you's all know how I go when have replaced & checked. Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1323772 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 3m 19d Posted 12/11/12 12:57 AM Share Posted 12/11/12 12:57 AM Those codes relate to map sensor. Change it. But book into a well known shop ASAP. Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1323825 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 3m 19d Posted 12/11/12 12:58 AM Share Posted 12/11/12 12:58 AM Not ALL those codes relate to map sensor by the way. But a few of them do. But the sensor could e fine and the wiring could be at fault. Link to comment https://www.fordxr6turbo.com/forum/topic/82759-how-many-bar-is-a-xr6t-fuel-regulator/page/3/#findComment-1323827 Share on other sites More sharing options...
