Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 20d Gender: Male Location: Perth Posted 26/08/13 08:08 AM Share Posted 26/08/13 08:08 AM Mine is tucked away inside the centre console bin.My biggest gripe is that there is no relationship between the set point value and actual boost pressue. The SP is the wastegate solenoid duty cycle yet wastegate locking and overboost shut down are a function of boost pressure.My point is 15psi is not 15psi Set Point, it could be an SP of 22=15psi. The system has the ability to function in a semi closed loop fashion (you can set an overboost function that will cut wastegate duty cycle until the boost pressure drops to half of the over boost value so I cannot see what they firmware couldn't be updated to make the boost setpoint an actual PSI function not a set pointMaybe I should ring Turbosmart...?? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1418963 Share on other sites More sharing options...
mummba Member 525 Member For: 15y 2m 7d Gender: Male Location: perth Posted 26/08/13 11:53 AM Share Posted 26/08/13 11:53 AM ^^ yeh mate give them a call!! I would like to pick your brain about my set up ralphy, see what your thoughts are with my 4 port solenoid, and when my gates are cracking Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419079 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 20d Gender: Male Location: Perth Posted 26/08/13 11:55 AM Share Posted 26/08/13 11:55 AM Are you planning to turn up on the 6th? Happy to discuss then, or if not wadyawannaknow? Toads also knows his way around an eboost. Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419080 Share on other sites More sharing options...
mummba Member 525 Member For: 15y 2m 7d Gender: Male Location: perth Posted 26/08/13 12:03 PM Share Posted 26/08/13 12:03 PM yeh he is as switched on as it gets I think...na mate will be in qld for powercruise over therejust have a few questions in regards to the 4 port solenoid and to see your thoughts and experience with them Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419082 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 6m 4d Gender: Male Location: left right out Posted 27/08/13 06:40 AM Share Posted 27/08/13 06:40 AM Thanks for that Ralphy, you can set the psi in live mode though I guess, just seems dodgy doing it whilst driving. I agree it should be logical as you explained. Maybe when they update to something like the new Greedy profec - http://www.greddy.com/products/electronics/profec/I like the boost map feature, you can see spikes etc a bit easier.Anyway I think Eboost is still the leader, ordered mine today Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419232 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 5d Gender: Male Location: OZ Posted 27/08/13 11:08 AM Share Posted 27/08/13 11:08 AM On 26/08/2013 at 12:03 PM, mummba said: yeh he is as switched on as it gets I think...na mate will be in qld for powercruise over therejust have a few questions in regards to the 4 port solenoid and to see your thoughts and experience with them4 port solenoids are used to run a wide range of boost pressures and are usually used with soft springs.....I.e. 7psi spring could run between 7psi and 25+psi for example. A 4 port connection running twin 14psi springs/gates and only wishing to run 21psi is not ideal in my opinion, however your dynograph is good. Even Turbosmart state that this set-up 'has varying degrees of success'!! But in the end of the day if you are maintaining your desired boost and you're never over-boosting, then happy days! Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419326 Share on other sites More sharing options...
mummba Member 525 Member For: 15y 2m 7d Gender: Male Location: perth Posted 27/08/13 10:22 PM Share Posted 27/08/13 10:22 PM On 27/08/2013 at 11:08 AM, IH8TOADS said: 'has varying degrees of success'!! I did see this on there e-boost pfd, witch I thought was funny..definatly not worried about it, infact I prefer them to stay closed as long as possible.. another benefit is its not the quietest on the road when open haha Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419411 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 5d Gender: Male Location: OZ Posted 28/08/13 12:50 AM Share Posted 28/08/13 12:50 AM I could barely hear your gates wen they opened hahaha....not!!! Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419442 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 20d Gender: Male Location: Perth Posted 28/08/13 02:02 AM Share Posted 28/08/13 02:02 AM ^ 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419461 Share on other sites More sharing options...
chaydon1 Member 42 Member For: 12y 2m 24d Gender: Male Posted 28/08/13 10:10 AM Share Posted 28/08/13 10:10 AM Im running a Greddy Profec2 and love it. Gotta spend the time though. The mr policeman wouldnt really be to happy about the controllers would they? Anyone had any troubles? Link to comment https://www.fordxr6turbo.com/forum/topic/82750-eboost2-topic/page/4/#findComment-1419550 Share on other sites More sharing options...
