broke Donating Members 229 Member For: 13y 3m 29d Gender: Male Posted 06/11/12 06:49 AM Share Posted 06/11/12 06:49 AM hey guys, just thought I'd post a thread asking some opinions on what a rattle under what appears to be the rocker cover up the front (on the red part.) it seems to only happen when the engine is hot and I've been feeding it a bit of boost. I did the screw driver trick (good one that) and it's almost certainly coming from under the cover. Noisy chain or something, perhaps it's a bit loose? It comes and goes periodically. It's due for an oil change as I think last service they just gave me Magnatec. I'll try better oil when I get paid on Thursday and see if it keeps doing it. Should I try maybe a thicker oil? Or just stick with the 10w-40 stuff? Car behaves perfectly normal and doesn't seem to be having an ill effects other than a subtle rattle. Only audible when im pulling the car into the garage where all the sound is bouncing off the walls.cheers guys Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 7d Gender: Male Location: Penrith Posted 06/11/12 07:37 AM Share Posted 06/11/12 07:37 AM I had the same issue swore blind it was from the rocker cover it turned out to be a pulley. only did it when hot and only periodically. Took the tuner 2 days for it to make the noise for him but changed the pulley never made the sound again Link to comment Share on other sites More sharing options...
broke Donating Members 229 Member For: 13y 3m 29d Gender: Male Posted 06/11/12 08:03 AM Author Share Posted 06/11/12 08:03 AM I had the same issue swore blind it was from the rocker cover it turned out to be a pulley. only did it when hot and only periodically. Took the tuner 2 days for it to make the noise for him but changed the pulley never made the sound againive changed the idler pulley but maybe it's the tensioner this time Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 7d Gender: Male Location: Penrith Posted 06/11/12 10:00 AM Share Posted 06/11/12 10:00 AM it was the tensioner on mine Sorry forgot to put that in the first post... Link to comment Share on other sites More sharing options...
