xr6boosted Member 67 Member For: 13y 29d Gender: Male Location: QLD Posted 31/10/12 12:46 AM Share Posted 31/10/12 12:46 AM Hi All,Can someone please confirm if the coolant reservoir is supposed to have an overflow hole at the bottom or not?Mine is leaking from the bottom and I am just unsure if it's cracked or just deliberately overflowing due to a failed thermostat. The thermostat pipe also is showing signs of a failed o-ring with spots of burnt coolant. I have ordered a new thermostat but just not sure if I should be ordering a new reservoir or not..Also my reservoir is a replacement item I picked up from ebay recently..Thanks heaps. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 3m 3d Gender: Male Location: SE Melbourne Posted 31/10/12 01:14 AM Share Posted 31/10/12 01:14 AM No does not have overflow. If it isn't genuine there could be a small one near the cap. Check all hoses to make sure they are on properly and clamped. Link to comment Share on other sites More sharing options...
xr6boosted Member 67 Member For: 13y 29d Gender: Male Location: QLD Posted 31/10/12 01:46 AM Author Share Posted 31/10/12 01:46 AM (edited) It's definately the reservoir that's leaking from the bottom, can't believe anyone would bother selling a product that fails so quickly..So does a thermostat failure cause excess pressure in the coolant system? Edited 31/10/12 01:56 AM by xr6boosted Link to comment Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 7m Gender: Male Location: Perth Posted 31/10/12 02:08 AM Share Posted 31/10/12 02:08 AM Higher operating temp from a faulty thermostat will cause excess pressure. Link to comment Share on other sites More sharing options...
KeddyXR6T Donating Members 320 Member For: 15y 11m 18d Gender: Male Location: Melbourne Posted 31/10/12 02:24 AM Share Posted 31/10/12 02:24 AM (edited) Also my reservoir is a replacement item I picked up from ebay recently + Higher operating temp from a faulty thermostat will cause excess pressure and Bang theres your problemsame thing with a work ute Edited 31/10/12 02:25 AM by KeddyXR6T Link to comment Share on other sites More sharing options...
xr6boosted Member 67 Member For: 13y 29d Gender: Male Location: QLD Posted 31/10/12 03:28 AM Author Share Posted 31/10/12 03:28 AM (edited) Probably no point swapping out the reservoir until the new thermostat arrives, don't want to cook another one..Funny thing is, the temperature gauge hasn't moved.Thanks for your help guys. Edited 31/10/12 03:28 AM by xr6boosted Link to comment Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 17y 10m 28d Gender: Male Location: Adelaide Posted 31/10/12 07:26 AM Share Posted 31/10/12 07:26 AM Some temp guages won't register if theres no coolant in the system. Obviously yours has coolant cause its leaking but don't rely on temp guage when driving. Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 6m 29d Gender: Male Posted 31/10/12 08:04 AM Share Posted 31/10/12 08:04 AM Actually becasue the falcons use a cylinder head temp sensor which is an ntc thermistor it will register high temp when not in contact with coolant, theres probably nothing wrong with your thermostat but its easy to test with a kettle full of water, id say the header tank is just stuffed, not uncommon Link to comment Share on other sites More sharing options...
xr6boosted Member 67 Member For: 13y 29d Gender: Male Location: QLD Posted 31/10/12 11:25 PM Author Share Posted 31/10/12 11:25 PM Also FYI - The coolant reservoir does have an overflow hole at the bottom that runs straight down the centre from the side of the cap at the top. I have a feeling this is the weak point of where mine is leaking from. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 3m 3d Gender: Male Location: SE Melbourne Posted 31/10/12 11:39 PM Share Posted 31/10/12 11:39 PM are you able to post a pic? Link to comment Share on other sites More sharing options...
