Turbo Conversion On Na Engine *pinging Help?
FairlaneG
  • Member For: 18y 6m 4d
Dr emmit brown stole plutonium of the libians.. They later found him at the pines mall which the shot him
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 1d
Many lols after the works done
But op what were u thinking getting even a base generic tune for ? That thing should of been started for the first time on the dyno
  • Skid Machine
  • Member For: 13y 10m 8d
Even though I'm now turboless, I'll continue to come back to this forum. Not for the expertise of others, just for the lol's.
To the OP get the car checked on a dyno before you put it on the straight as that will help diagnose most of your issues.
  • Moar Powar Babeh
  • Member For: 19y 6m 9d
OP
Car needs to be custom tuned properly. An off the shelf tune with no boost control will not be able to prevent the car from Pinging. Your car has a much higher static comp ratio than a turbo motor so it will need the tune adjust to suit.
Re the misfire, It could be a dud coil or it could be as simple as a incorrect plug gaps, When is it miss firing? If its only underboost it could be plug gaps or it could be leaning out under boost. If its a consistent miss fire under all conditions you could be looking at a dud coil or dud cylinder. (did it start are it rattled on boost?)
  • BANNED
  • Banned
  • Member For: 17y 11m 4d
  • Gender: Not Telling
  On 31/10/2012 at 12:14 AM, Ralph Wiggum said:
Answered both his questions.
What did you contribute?
I drove 800km round trip to give him a fuel pump so he good start it on the weekend !!!
  • Like 2
  • Member For: 12y 9m 8d
To nurse it to the dyno.
  On 31/10/2012 at 12:34 AM, Ralph Wiggum said:
OP
It seems to misfire at idle more. Around 1200RPM same misfire. Around 3000 RPM it seems to not be there.
" (did it start are it rattled on boost?) " Pardon?? Rattle when on boost did you mean?
Ok. Here is the diagnostic found by sound not by Data.
1st gear nursed to 2nd gear. 2nd gear nursed to 3rd gear.When it goes into 3rd 'Ghia (about 2000RPM) nursing & increasing throttle to get to 4th 'Ghia it pings(rattles)
Edited by FairlaneG
