  • Member For: 15y 2m 29d
Hi Ralph, would there be a chance you may ask the person who has made these if he can make or has made a set for BA/BF - E series?
Cheers
Leigh
  • 8 months later...
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 3m 26d
I'm considering a set of the redesigned Technico ones as one of mine is rooted.
Other than some vibration (which may or may not be dialed out with idle adjustment) will there be any other nasty side effects? other random bolts loosening?
  • Member For: 17y 4m 18d
Note: exhaust leaks kill them fairly fast so make sure everything is in tip top shape. I've killed one totally and the replacement is dying fast even with a better heat shield on it! Hardly a criticism though, just my slackness causing it. Robert from Technico has been great to deal with too.
  • ʎǝʞuoɯ ɹoıuǝs
how do you mean? are they less durable than the factory mounts?
I have a set of inconel studs for the turbo flange and stage8 bolts to go on when I do this job. might even send the exhaust mani off to get ceramic coated just because while its all in bits.
Edited by SuckSqueezeBangBlow
Don't know as I didn't have this leak with the factory ones in there so can't directly compare.
