HI PSI Member 1,586 Member For: 18y 9m 14d Gender: Male Location: Central Queensland Posted 06/11/12 10:41 PM Share Posted 06/11/12 10:41 PM Is it necessary to replace both mounts, as only one mount would be likely to fatigue due to torsional forces?Brad Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 2m 21d Gender: Male Location: North West Hot Hell,VIC Posted 07/11/12 07:47 PM Share Posted 07/11/12 07:47 PM They both fatigue,the passenger one gets streched under torque load while the driver side gets compressed. you are better off replacing both mounts. Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 4m 14d Gender: Male Location: Far north queensland Posted 24/11/12 06:46 PM Share Posted 24/11/12 06:46 PM updates??????? 1 Link to comment Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 6m 4d Gender: Male Location: Melbourne Posted 25/11/12 03:30 PM Share Posted 25/11/12 03:30 PM :stupid2: Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 29/11/12 01:21 AM Author Share Posted 29/11/12 01:21 AM Sorry gents missed this, well mixed feelings about the mounts. The improvement in handling and gear shifts under load is excellent, the increased vibration is not.In the transition under load between 700 and 980 rpm the is a substantial increase in NVH, and this also translates to more vibration at idle. Bumping the idle to 1000 stops this but on my car this is quite annoying as my Forgies are singing their merry tune at that rpm point.I need to replace my 70k Km old vibration damper and see if this improves the vibration at idle. Im also considering talking to P@ @ WHS about a set of "softer" bushed for the mounts.Would I buy again? Yes I would.I can't fault the quality its just the side effects in my particular car are greater than I would have liked. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 4d Gender: Male Location: SW Sydney Posted 29/11/12 01:24 AM Share Posted 29/11/12 01:24 AM Are the standard ones rubber or some form of poly?Edit: I'm talking about the standard bushes in the billet mounts Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 29/11/12 01:26 AM Author Share Posted 29/11/12 01:26 AM as far as I can tell natural rubber Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 4d Gender: Male Location: SW Sydney Posted 29/11/12 01:29 AM Share Posted 29/11/12 01:29 AM In that case I would say that its not the compound rather the size of the bush. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 29/11/12 01:32 AM Author Share Posted 29/11/12 01:32 AM possibly, I need to pull them out and see if there is any evidence of metal on metal contact. As I mentioned above I also need to replace the balancer, so will do that before I go chasing rainbows with the Bushes 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 27/12/12 05:55 AM Author Share Posted 27/12/12 05:55 AM Update: Whilst pulling the engine out last weekend I discovered and Issue with the Drivers side mount, The bushes had become quite loose on the crush tube and there was quite a bit of slop in the mount. I had been getting a slight metallic "ting" when releasing the clutch and I believed at first the exhaust was contacting the center bearing mount as the clearance was quite small. It turns out the noise was the crush tube contacting the spacer ring inside the bush. I took some happy snaps of the failed mount and emailed them off to Robert @ Technico sunday night, received a response by the time I got out of bed monday morning and sit here now at my desk with a brand new set of poly bushed mounts in my hand. Pretty awesome service especially considering we had Christmas and Boxing day in the mean time! i cannot say enough good things about the service from Robert, it really nice to deal with and aussie company supplying aussie made products and following through on what they say they will do.So if I get a chance I will be fitting the polybushed units this weekend. Robert has advised me that there willl be an increase in vibration until the units fully settle in so once I have put a couple of thousand KM's on the mounts I will report back! 2 Link to comment Share on other sites More sharing options...
