Aftermarket Billet Engine Mounts
Ralph Wiggum
  • Silver Donating Members
  • Member For: 19y 2m 21d
They both fatigue,the passenger one gets streched under torque load while the driver side gets compressed. you are better off replacing both mounts.
  • 3 weeks later...
  • Moar Powar Babeh
  • Member For: 19y 5m 16d
Sorry gents missed this, well mixed feelings about the mounts. The improvement in handling and gear shifts under load is excellent, the increased vibration is not.
In the transition under load between 700 and 980 rpm the is a substantial increase in NVH, and this also translates to more vibration at idle. Bumping the idle to 1000 stops this but on my car this is quite annoying as my Forgies are singing their merry tune at that rpm point.
I need to replace my 70k Km old vibration damper and see if this improves the vibration at idle. Im also considering talking to P@ @ WHS about a set of "softer" bushed for the mounts.
Would I buy again? Yes I would.
I can't fault the quality its just the side effects in my particular car are greater than I would have liked.
  • Moar Powar Babeh
possibly, I need to pull them out and see if there is any evidence of metal on metal contact. As I mentioned above I also need to replace the balancer, so will do that before I go chasing rainbows with the Bushes
  • 4 weeks later...
  • Moar Powar Babeh
Update: Whilst pulling the engine out last weekend I discovered and Issue with the Drivers side mount, The bushes had become quite loose on the crush tube and there was quite a bit of slop in the mount. I had been getting a slight metallic "ting" when releasing the clutch and I believed at first the exhaust was contacting the center bearing mount as the clearance was quite small. It turns out the noise was the crush tube contacting the spacer ring inside the bush.
I took some happy snaps of the failed mount and emailed them off to Robert @ Technico sunday night, received a response by the time I got out of bed monday morning and sit here now at my desk with a brand new set of poly bushed mounts in my hand. Pretty awesome service especially considering we had Christmas and Boxing day in the mean time! i cannot say enough good things about the service from Robert, it really nice to deal with and aussie company supplying aussie made products and following through on what they say they will do.
So if I get a chance I will be fitting the polybushed units this weekend. Robert has advised me that there willl be an increase in vibration until the units fully settle in so once I have put a couple of thousand KM's on the mounts I will report back!
  • Like 2
