What Injectors Should I Get?
  • Member For: 19y 6m 27d
Can you post some details of spray type. Single 15 degree cone for example. There seems to be a few types of these going around. Post some calibration data if its available. Are these a ball and seat design or a director plate?
  • Waiting for the 1st N/A 12!
  • Member For: 16y 11m 24d
Some info I gained overnight.
Five O will send me some data soon.
FIVEOMOTORSPORT, INC. introduces the new generation BLACK-OPS M95 1000CC FUEL INJECTOR -These sets are exclusively flow-matched for engines that use a Long-3.0" injector with USCAR electrical connector
After several years of R&D and testing many different injector core/body configurations, Fiveomotorsport is releasing the new Black-Ops M95 for sale to the auto enthusiast for street-performance vehicles.
Our custom-manufactured 1000cc version brings ultra-fast latency times never seen before in modern EV14/EV6-style high impedance fuel injectors.
Quicker than even the best low impedance injectors. For example the dead-time at 16 volts is an unbelievable 0.300 ms.
That is the fastest high impedance or low impedance 1000cc injector Fiveomotorsport has ever been able to offer
FREE. Each injector comes with an EV6 female pigtail.
This same injector in a low-flow version has been used by General Motors for several years and has been proving its durability and consistency in OE applications--partly due to its new larger insulated coil. Notice the 17 mm body (see  photos) - approximately 2 mm larger than a standard EV14 1000cc injector. Our custom-milled 1000cc version brings ultra-fast latency times never seen before to modern EV14/EV6-style high impedance fuel injectors.
Similarly quicker than even the best low impedance injectors. For example the dead-time (latency) at 16 volts is an unbelievable 0.300 ms.That is the fastest high impedance or low impedance 1000cc injector Fiveomotorsport has ever been able to offer.The larger coil shows itself in another positive way in the new Black-Ops M95 fuel injector. Fiveomotorsport is able to guarantee sets from 2 to 12 injectors matched statically and dynamically to within 0.5% of each other.Now lets talk about Fiveomotorsport's newsingle-hole, split-fountain fuel outlet nozzle. This new nozzle guarantees a tight cone spray throughout the rpm range. And where it gets really good is at high volume/high rpm.Testing has been completed and soon we will have a video illustrating the Black-Ops M95operating at 9,000 rpm and firing for only 1-1.5 ms. Realize the test chamber is filing with Heptane, without mixing with air, under no pressure and no vacuum, unlike an actual engine combustion chamber. Even with the simulated conditions you will still see the super-fine droplets our new single-hole nozzle produces.Our other videos will show wide-open testing at 3 bar/43.5 PSI and pulse testing at up to 7 bar/101.5 PSI. You will be able to experience, first-hand, the specialness of our new split-fountain spray nozzle,translating in to an injector like no other available. That's the new Fiveomotorsport Black-Ops M95.
Buyer Beware - You may be purchasing the best-ever 1000cc fuel injector yet produced.This injector can provide a smooth idle quality on most engines running all types of gasoline and E85. We, of course recommend seeking a pro-tuner. With a pressure capability of 7 BAR this injector will flow at up to 1600 cc/min with excellent low pulse width linearity, and has a broad operating range equal to any (EFI) injector on the market.Buy 'em and get a 5% discount instantly when purchasing 4 or more M95 injectors.Just use discount code M9510005 when checking out.
Fuel Injector Specifications: (Complete data sheet sent with each set).
Coil Resistance: 12 OHMS
Sets are delivered in flow rates ranging from 1000 to 1020 cc.
Latency (dead time): 0.450 ms at 14 volts
You will get a set that is exactly matched within a best-in-the-business 0.5%.Dimensions:Overall length: 74 mm - 2.9 in
Diameter: 17.1 mm - 0.70 inO-ring to o-ring, on center: 65 mm - 2.6 inO-ring diameter: 14.2 mm - 0.55 inO-ring material: Viton - upper, lower
Well at 3bar and 14v a 60lb deka is slightly quicker reacting at 0.44ms, so they are not correct regarding the reaction times never seen before!
I like how they say the 'specialness' lol.
I reserve judgement until I see some quality data.
As I said before toads someone always has to be 1st and to date we have been really happy with them. And fir my tuner to ask me time get more as he feels they outperform ID's in a few areas.
didn't five0 upset a few people last year by selling chinese "bosch" injectors?
That's news to me.
Where did you hear that?
  • 4 weeks later...
  • Carnage on the Garage Floor
  • Member For: 14y 8m 24d
Looking into this myself atm. I can get 1000cc xspurts with connectors to suit for $670 to my door. So either them or the KPM 1000's are the front runners. Like that KPM match them - think xspurts do that also actually.
  • Member For: 19y 3m 13d
All injectors are latest technology brand new Bosch EV14
KPM in-house match set to within +/- 1%
We will guarantee each set off injectors 100%.
deliver is usually next day australia wide.
All injectors incude free adaptor plugs if needed
Correct Australian model scaling with each set
No U.S or Online store middle man
Speak with us directly at any time
complete fuel system and pump modules to match if required
Best ongoing pricing and service
We are a phone call awayon all your fuel injector and fuel system advice and technical information.
We have an Australia and New Zealand wide workshop dealer network specifically using our Fuel injectors and fuel system products that can help with your needs if you require.
Our service ,products and back up is second to none.
KPM Motorspport
08 82999998
david@kpmmotorsport.com.au
Purchase direct, online or from your local street fighter dealer.
Edited by KPM Motorsport
