stee3 Member 194 Member For: 13y 10m 4d Posted 04/12/12 01:19 AM Share Posted 04/12/12 01:19 AM (edited) On 03/12/2012 at 10:58 AM, Adam said: My understanding is tube and fin flows more than bar and plate.Bar and plate cools better than tune and fin.I'd rather bar and plate.Incorrect your theory is not right. You need to look at turbocharger size and the efficiency of the turbocharger as well. Intercooler efficiency is measure in more areas than just "cools better" On an engine with a GT35 or similar frame turbo I could agree that a tube and fin intercooler would be more efficient for daily use and abuse. On a larger frame turbocharger like a GT42/45/47 which has higher flowing capacity you will find that a tube and fin intercooler will be more efficient. Its not about how well an intercooler cools, its matching the right intercooler to the rest of the gear. After testing and data logging all my mates coolers and trying about 3 different types of intercoolers on my last car I went with a tube and fin on the street. I sacrificed 2-4degrees of cooling for an intercooler with less pressure drop meaning more response. I would rather sacrificed 2-4degrees of cooling making my turbo work less meaning lower engine bay temps. Lastly we could debate this all day but all bar and plate coolers are not made the same and the same goes for tube and fin. Some will be more efficent than other, other will be worse factor that in as well. Edited 04/12/12 01:19 AM by stee3 Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1333292 Share on other sites More sharing options...
stee3 Member 194 Member For: 13y 10m 4d Posted 04/12/12 04:40 AM Share Posted 04/12/12 04:40 AM On 04/12/2012 at 1:19 AM, stee3 said: Incorrect your theory is not right. You need to look at turbocharger size and the efficiency of the turbocharger as well. Intercooler efficiency is measure in more areas than just "cools better" On an engine with a GT35 or similar frame turbo I could agree that a tube and fin intercooler would be more efficient for daily use and abuse. On a larger frame turbocharger like a GT42/45/47 which has higher flowing capacity you will find that a tube and fin intercooler will be more efficient. Its not about how well an intercooler cools, its matching the right intercooler to the rest of the gear. After testing and data logging all my mates coolers and trying about 3 different types of intercoolers on my last car I went with a tube and fin on the street. I sacrificed 2-4degrees of cooling for an intercooler with less pressure drop meaning more response. I would rather sacrificed 2-4degrees of cooling making my turbo work less meaning lower engine bay temps. Lastly we could debate this all day but all bar and plate coolers are not made the same and the same goes for tube and fin. Some will be more efficent than other, other will be worse factor that in as well.Should read:Incorrect your theory is not right. You need to look at turbocharger size and the efficiency of the turbocharger as well. Intercooler efficiency is measure in more areas than just "cools better" On an engine with a GT35 or similar frame turbo I could agree that a BAR AND PLATE intercooler would be more efficient for daily use and abuse. On a larger frame turbocharger like a GT42/45/47 which has higher flowing capacity you will find that a tube and fin intercooler will be more efficient. Its not about how well an intercooler cools, its matching the right intercooler to the rest of the gear. After testing and data logging all my mates coolers and trying about 3 different types of intercoolers on my last car I went with a tube and fin on the street. I sacrificed 2-4degrees of cooling for an intercooler with less pressure drop meaning more response. I would rather sacrificed 2-4degrees of cooling making my turbo work less meaning lower engine bay temps. Lastly we could debate this all day but all bar and plate coolers are not made the same and the same goes for tube and fin. Some will be more efficent than other, other will be worse factor that in as well. Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1333358 Share on other sites More sharing options...
PJ. Member 22 Member For: 16y 9m 12d Gender: Male Location: Sydney Posted 04/12/12 10:06 PM Share Posted 04/12/12 10:06 PM You sound like you're on the money, although 99% of OEM intercoolers (cars and trucks) and radiators ARE tube and fin, not bar and plate.Bar and plate was specifically designed for custom sizes. Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1333618 Share on other sites More sharing options...
stroller SHLAMBD. Member 259 Member For: 12y 11m 24d Gender: Male Location: Perth NOR Posted 02/02/13 03:09 AM Share Posted 02/02/13 03:09 AM what are peoples thoughts on the rapid systems coolers compared to process west, plazmaman etc. ? Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1357443 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 13d Gender: Male Posted 03/02/13 10:17 PM Share Posted 03/02/13 10:17 PM (edited) Went to the Fast Torque Performance Engineering Concept Dyno Night last week,There will be regular dyno nights held utilizing the latest Mainline 2500 hp chassis dyno.The PW Stg 2 performed very well on my car and made 401rwkw on the first run and then backed up with 406rwkw on the second run.Have been very happy with my PW Kit and can see why Kevin passionately backs his products. Edited 03/02/13 10:19 PM by rednose Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1358198 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 4m 22d Gender: Male Location: CQ Posted 04/02/13 01:25 AM Share Posted 04/02/13 01:25 AM On my old bf I went from a pw stage 1 to a rapid 3 I think and the rapid was much bigger but my gains were very minimal (not worth it), I'm now onto my 3rd xr6t and I won't go anything other then pw, but people also rave about plaz...just my 2cents Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1358256 Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 4m 26d Gender: Male Location: Sydney Posted 05/02/13 01:44 AM Share Posted 05/02/13 01:44 AM george your car was bloody inpressive on the dyno pulled very consistant power sounded tops and there was like 2 people watching the car first run and the second was like 40 people just shows what the xr6t can do you have a ligit 400+ rwkw and it good to be around people who dont talk constant sh*t, I look forward to the next dyno day. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1358836 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 13d Gender: Male Posted 05/02/13 03:40 AM Share Posted 05/02/13 03:40 AM On 05/02/2013 at 1:44 AM, relentless xr6 said: george your car was bloody inpressive on the dyno pulled very consistant power sounded tops and there was like 2 people watching the car first run and the second was like 40 people just shows what the xr6t can do you have a ligit 400+ rwkw and it good to be around people who dont talk constant sh*t, I look forward to the next dyno day.Thanks Chris, was really happy that it made what it normally makes on Spiros dyno.Also happy that it backed it up on the second run. Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1358892 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 30d Gender: Male Location: Adelaide Posted 05/02/13 06:44 AM Share Posted 05/02/13 06:44 AM Good work george !!I have the fg nizzy cooler kit but I also have a big front mount zf cooler and on power runs 2/3/4 my power drops , due to the heat the trans cooler soaks into the intercooler out let area but iam more inclined to have dipping power on the dyno but a cool zf It was always going to be a trade off ( did the same thing on my ba ) but ive also got a original zf and I honestly think " keeping cool " the zf has kept it in one piece but at sometimes a big trade off for top end kw Having your cake and eating it is harder and harder at big power 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1358957 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 13d Gender: Male Posted 05/02/13 06:56 AM Share Posted 05/02/13 06:56 AM On 05/02/2013 at 6:44 AM, J@SNOT said: Good work george !!I have the fg nizzy cooler kit but I also have a big front mount zf cooler and on power runs 2/3/4 my power drops , due to the heat the trans cooler soaks into the intercooler out let area but iam more inclined to have dipping power on the dyno but a cool zfIt was always going to be a trade off ( did the same thing on my ba ) but ive also got a original zf and I honestly think " keeping cool " the zf has kept it in one piece but at sometimes a big trade off for top end kwHaving your cake and eating it is harder and harder at big powerYou can always have your cake and eat it, otherwise what's the point?Move the trans cooler elsewhere and you wont have that issue. Link to comment https://www.fordxr6turbo.com/forum/topic/82597-most-efficient-intercooler-for-fg/page/7/#findComment-1358960 Share on other sites More sharing options...
