  • Member For: 16y 11m 3d
  On 23/07/2014 at 10:57 AM, arronm said:
Only 12?????????????????????
Yep, that'll do for a few months. I like to get 'em fresh (ie lots of small bottles instead of one big one).
But yeah, you're right... one box isn't enough... two boxes (ie 24 bottles) would have been preferable. Damn shame they're now closed for the day.
There needs to be a home delivery service for brake fluid bottles, like old fashioned milkmen. Wake up and there's a box of brake fluid bottles on the front door step.
Edited by PhilMeUp
  On 22/07/2014 at 7:22 AM, bamk2f6tornado said:
You can get those hose separators above from Pirtek for like $4 each. Come in black blue silver and red. In heaps of sizes. I used them for my earls oil feel line
I stopped by at a Pirtek today and was given a price of $8.90 each one. How did you manage to get them for $4 each?
Found this - some part numbers and pricing: http://www.vpw.com.au/Category/Index/431483
They are distributed by Proflow.
What size? I've just measured the outside diameter of the aluminium pipe in the engine bay and it was roughly 8mm. The braided hose in the kit is about the same. Wouldn't that require an 8mm separator? The -5AN that hawlass mentioned is 12.7mm.
  On 22/07/2014 at 1:06 PM, Ralph Wiggum said:
WA peps Couplers Malaga carry billet line clamps at very reasonable prices.
Page 41 in the PDF: http://www.couplers.com.au/wp-content/uploads/2013/06/performance-catalogue-20131.pdf
  • Bronze Donating Members
  • Member For: 11y 6m 16d
I have no idea why they are probably ripping you off. I live up in central qld were everything is a bit more expensive and to pay for express shipping as well but still worked out to $4 Inc postage.
  • Member For: 12y 11m 12d
Not sure what size I brought.
I just got the size to fit the pipe work, and then lined the clip with a strip of rubber to hold the braided line.
Edited by GeGe6
  • Member For: 17y 7m 10d
PhilMeUp,
I think the confusion around AN sizing is due to it being based on I.d. sizing, where most hoses are measured o.d. Even then there is no gaurantee when it comes to fittings.
This may help explain- https://www.pegasusautoracing.com/document.asp?DocID=TECH00096
I have just had a measure of the braided line and its 7.8mm o.d. ,and looking at my receipt, it lists the line as -4AN (id of course).
The clamps I have are listed as 5/16 (7.9mm), which would make them -5AN o.d. They fit snug but can be turned slightly, so a strip of rubber between the clamp and hose as GeGe6 suggested would work. I may simply file the two flats of the clamp to reduce the I.d. and increase clamping pressure.
I suspect the clamp details in the ali express listing may be a little off with the 12mm measurement, not uncommon in chinglish listings to get lost in translation.
So in summary, -5AN seperator clamps will fit our turbo oil line braided hose, as they are 5/16 I.D. and the hose is 5/16 O.D. or thereabouts.
Hawlass, is yours is BA/BF?
The steel tube on my FG was 12mm there about, hence the need for rubber strip on 7.8mm braided.
Seems to be a difference in O.D. on the steel tube between BF and FG.
Edited by GeGe6
