Earls Filter Fitted...with A Difference..
Peter J
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 10d
No washer
Then do this really super technical thing
Run it for a while and look at it..... U know make sure its not leaking
Here is another tip ( not so technical ) remove the rear heat shield so u can get the spanner in to the core and reduce the risk of rounding the nut, it helps a fair bit ;)
  • Member For: 17y 5m 19d
So the bottom but doesn't screw all the way in but it has come end so I assume that is the mechanical seal. Next problem is how the hell do you tighten the feed line in that space
Only a lot easier. It can't be done up without taking the shield off. Obviously my mechanic didn't want the hassle of doing that.
No leaks so far
