demon1300 Member 435 Member For: 13y 4m 8d Gender: Male Posted 24/10/14 10:08 AM Share Posted 24/10/14 10:08 AM They fit perfectly fine on mine... Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1507984 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 7m 8d Gender: Male Location: left right out Posted 24/10/14 06:29 PM Share Posted 24/10/14 06:29 PM Each "-" is 1/16th of an inch, or about 1,5mm. so a -2 = 2x 1/16 (1/8") or about 3mm. - 4 = 4x 1/16 (1/4")or about 6mm. (its 6.35mm to be exact).Knowing this you can measure your steel hard lines in mm and work it out back to the dash system using this chart http://mdmetric.com/tech/cvtcht.htm Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1508034 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 26d Gender: Male Location: Darwin Posted 09/11/14 09:06 AM Share Posted 09/11/14 09:06 AM Dammit, had my mechanic install this a couple of days ago and after smelling burning oil for a couple of days I've worked out where it is coming from. Between the end of the oil feed line ( turbo side) and the original end of the line is leaking oil. Lost heaps, only just on the stick.Is is between the original bit that screws directly into the turbo and the end of the new feed line that is leaking. They have out some sealant on it but it is clearly not working. Was this supposed to have been removed and the new feed line directly screwed into the turbo?If not what sealant should I use to fix it. Totally not worth the $100+ labor. Only got the mechanic to do it as the fuel pump died and it was already in the shop. Sent from my iPad using Tapatalk HD Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511250 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 26d Gender: Male Location: Darwin Posted 09/11/14 09:14 AM Share Posted 09/11/14 09:14 AM Right there I can't believe how much oil comes out 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511252 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 20d Gender: Male Location: near brisbane Posted 09/11/14 09:42 AM Share Posted 09/11/14 09:42 AM mine is a ba ,but it fitted straight into the turbo . I would undo it and apply some lock tight sealant (apply to thread only ) best of luck with it Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511258 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 17d Gender: Male Location: Adelaide Posted 09/11/14 09:57 AM Share Posted 09/11/14 09:57 AM Norrs Your mechanic is a peanut It goes into the turbo core , piss that stand off that the new oil line is screwed into ( hence the leaking ) 2 Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511260 Share on other sites More sharing options...
Spyathe Donating Members 872 Member For: 11y 7m 19d Gender: Male Posted 09/11/14 10:45 AM Share Posted 09/11/14 10:45 AM Also, no sealant is required, it is a mechanical seal Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511272 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 25d Gender: Male Location: Perth Posted 09/11/14 11:28 AM Share Posted 09/11/14 11:28 AM Sealant is good for the bearings, takes up all the clearance and slows them right down. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511298 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 26d Gender: Male Location: Darwin Posted 09/11/14 12:36 PM Share Posted 09/11/14 12:36 PM Thanks guys I'll do it myself in the morning. Frickin glad I caught it just before I ran out if oil Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511327 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 26d Gender: Male Location: Darwin Posted 09/11/14 12:37 PM Share Posted 09/11/14 12:37 PM Oh I see there is a washer at the bottom of the old one. Do I use that or just screw in the new line as is Link to comment https://www.fordxr6turbo.com/forum/topic/82552-earls-filter-fittedwith-a-difference/page/11/#findComment-1511330 Share on other sites More sharing options...
