Whistling Noise At The Drags
  • Member For: 12y 10m 13d
The ute has been going good lately and ford said there is nothing wrong,got the oil and filter done at 5000 and they plugged it in and its fine.No whistling to be heard so I guess I must just be used to the power now :cry:I checked the pipes in the engine bay and they were fine but couldnt be stuffed pulling the front bar off to check the other pipes. Its a hard one because I cant really tell them I had it at the drags :no2: anyhow it seems to be fine and no more trips down the strip for me.
So I may just do the diff bush and be done with it....
Edited by UEB302
its pretty easy to do a pressure test of your intake piping - a few threads about it here.
a little compressor - a tyre valve and a pvc end cap and some soap suds and you should be able to find it (I did)
or a tuner can use a smoke machine and its even easier (shouldn't be too expensive)
  • 2 weeks later...
  • 4 weeks later...
