  • Moar Powar Babeh
  • Member For: 19y 7m 11d
:facepalm:
Autocorrect fail, I meant battery offset table values...
Damn Iphone.
  • Member For: 22y 1m 4d
Whats your theory on this Ralphy. It didn't fall on deaf ears. Some tuning changes I did to some G302 injectors today stopped stalling once I started reducing the battery offsets from my theory figures derived from the Ford Racing Injector sheets
  On 31/10/2012 at 12:23 PM, Ralph Wiggum said:
:facepalm:
Damn Iphone.
  • Moar Powar Babeh
do you remember a while back I posted up the at min pulse width and battery offset @14v shouldn't exceed 1.5ms?
You posted up some pretty good stuff in that DIY tuning thread. Pitty to lock it though.
I did reread it. Knowing it shouldn't exceed 1.5ms is pretty important. With the GT500 injectors, I had it at 1.6972ms and experienced the spark source go crazy switching between 9 (idle spark) and 1 (base spark) at idle at times and always dipping into 1 when at idle.
I reduced it down to 1.6104 and it made a world of difference. It dipped heaps less and no crazy switching.
Is this a side effect you are talking about having it over 1.5ms. Can you explain more???
Nevertheless I am going to change it to under 1.5ms as you said by reducing min pulsewidth down and see if it totally stops it dipping into spark source 1 at idle.
  • Member For: 19y 9m 26d
Your low flow area of your custom tune injector calibration was 8% lean. when coming of the throttle and off the open loop base fuel table (and into the closed loop feedback) may have been causing some confusion. Cleaning up the trims can only help!
  • Member For: 14y 3m 15d
When I've tuned older e series, quick stopping/stalling under brakes etc are issues usually to do with a function of the dash pot decay Rate. Really testing my memory though haha. I've never actually tuned a b or f series myself from scratch but pretty sure they don't have a similar table.
Is there a table which directly tells the engine how quickly to drop revs under zero throttle?
I know e series ecu's are MUCH simpler than these but just thought I'd see if it ticked anthing in someone's head...
  • Moar Powar Babeh
turbotrana had some injector scaling issues that needed to be sorted first, but yes you are correct, idle air flow decay and dash pot decay help immensely with revs dropping to stall problems
