turbotrana Member 2,586 Member For: 22y 1m 4d Gender: Male Posted 29/10/12 09:24 AM Share Posted 29/10/12 09:24 AM On 29/10/2012 at 8:19 AM, turboknapp said: My car does this same problem intermittedly, I'm going to do some data logging with the Toadmaster see what the mad scientist can pick up.lets all meet up at a coffee shop and we can go for a datalog together. I will bring my laptop and then can see if its a similar problem to mine. Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1316888 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 4d Gender: Male Posted 29/10/12 09:27 AM Share Posted 29/10/12 09:27 AM I reduced the VSS that adaptive spark idle control comes in to 0kph (from 5kph) and that helped somewhat. Still not a fix though, just a fudge. Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1316891 Share on other sites More sharing options...
FGX 40T Donating Members 142 Member For: 15y 29d Gender: Male Location: WA - South of the River Posted 30/10/12 08:01 AM Author Share Posted 30/10/12 08:01 AM I had the car returned back to factory today - stock injectors and stock tune - while my tuner tries to work out what is causing the idle issue. Also he wanted to check if the problem persists or goes away. I guess he is trying to verify if the fault is from the factory program or a result of the tune. So far the car has not missed a beat (since returning to stock). I will do some more driving to ensure all is ok with the return to stock and let you all know. He also checked the Ford data base to see if there was an update for my vehicle - no update available- it is running the latest software. Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1317429 Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 18y 1m 6d Gender: Male Location: Adelaide Posted 30/10/12 08:50 AM Share Posted 30/10/12 08:50 AM On 23/10/2012 at 5:52 AM, IH8TOADS said: Yeah could be a common problem, or even something mechanical/service orientated...maybe a few mods and tune elevate it?A tune often means probs but I guess we expect to pay for more problems when modifying the cars. I have certainly seen a few cars with unnoticed existing issues that became apparent after a tune. There must be a reason some of us have no issues and some have lots? Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1317460 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 26d Gender: Male Location: OZ Posted 30/10/12 10:45 AM Share Posted 30/10/12 10:45 AM Well I started tuning cos small issues persisted.FG09T did he do any datalogging with the xcal3? Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1317551 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 8m 29d Gender: Male Location: Melbourne Posted 30/10/12 12:58 PM Share Posted 30/10/12 12:58 PM On 23/10/2012 at 4:03 AM, Paulie2256 said: annnnnnd jesus just found this thread. prepare for your idle to be healed. mate you make me laugh - we need you on the Snowy Cruise Hope someone can post up a workaround/resolution. Didn't realise so many of us were driving around in FGs that stalled easily 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1317631 Share on other sites More sharing options...
FGX 40T Donating Members 142 Member For: 15y 29d Gender: Male Location: WA - South of the River Posted 31/10/12 07:57 AM Author Share Posted 31/10/12 07:57 AM (edited) He did not use the Xcal 3 to data log - he used a ford program to stream live data from PCM. He was looking at fuel trims and some other stuff. He kept making adjustments to the tune and then flash it in and then stream the data again. This went on for several hours - for no result as previously posted. There was one setting in particular he was adjusting - he said according to ford it should read -0.05 or -0.5 cant remember. This particular parameter kept getting closer to the desired number after every adjustment and reflash (he was adding %'s of air) to the low rpm range in drive 550 to 650 - but never quite got there. He was concerned he was getting too far away from the factory settings and did not know why he had to add so much air to get this number down. That is about all I can remember. He said he would continue to look through the programming to hopefully find a remedy - but I do not think this is imminent. Since having the factory injectors and factory tune put back in the car has been perfect. Edited 31/10/12 07:57 AM by FG09T 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1318161 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 26d Gender: Male Location: OZ Posted 31/10/12 10:27 AM Share Posted 31/10/12 10:27 AM No worries, good luck with it. Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1318246 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 11d Gender: Male Location: Perth Posted 31/10/12 10:32 AM Share Posted 31/10/12 10:32 AM Delorean? Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1318249 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 26d Gender: Male Location: OZ Posted 31/10/12 12:20 PM Share Posted 31/10/12 12:20 PM Most likely! Link to comment https://www.fordxr6turbo.com/forum/topic/82495-fg-xr6t-tuner-help-required/page/5/#findComment-1318318 Share on other sites More sharing options...
