  • Member For: 19y 6m 7d
KPM and Streetfighter workshops Australia wide now can supply complete fuel system options for every BA-FG Sedan ,Ute and engine options.
With our full range of match flowed EV14 injectors coupled with our 460 or 600 in tank fuel modules, KPM have covered all your fuel system needs.
We offer a total solution by supplying our modules as a kit with all components a direct replacement fit, with plug in looms, and correct pressures for your application.
If you wish we can go a step further and supply the correct fuel injector for your vehicle, power level and fuel module.
We can even go a step further and supply you the SCT Flash Tuner with correct injector scaling so you can fit all your components yourself then drive your vehicle to have it tuned.
To save confusion and allow hassle free selection we have attached a chart below to aid in the correct intank fuel module and injector choice for your application.
All modules will be available as of next week
Contact
http://david@kpmmotorsport.com.au
08 82999 998
For more details
Edited by KPM Motorsport
  • Like 3
  • Forged Member
  • Member For: 18y 2m 22d
You guys seem to be bringing out some really well thought out products :spoton:
Can you tell me about the BA/F system? It looks similar to the factory in-tank module, how does your system combat surging? DIfferent pick up point? Small reservoir in the module?
Our Walbro 460 Module has a respectively large canister volume of 700cc which removes any surge issues on road.
We are currantly designing our Streetfighter module to suit the BA-BF range that holds 1300cc that can be used in all application inc motorsports without surge over 1000HP.
Nice work. A bloke I know has a vcm set up in his supercharged maloo and it works well.
We have been using twin intank modules on the Commodre for many years now with perfect results.
With only surge tanks available for the Fords , being illegal , quiet noisey and fumey, this is the main reason we have developed the same for the Ford models.
Our Streetfighter intank modules are whisper quiet, legal and supply more fuel/power than surge tanks. They will also supply fuel without surge down to an empty tank.
Fitmant is direct replacemant to the standard module.
So in an Fg looking for 350rwkw on E85 this is an option over going surge and 044?
This is exactly the scenario we have engineered this intank pump for. it is capable of up to 600 rwkw on E85 and 800 rwkw on 98 Octane. No surge!
  • Like 2
