B&E XR6 Member 8 Member For: 12y 9m 22d Gender: Male Posted 12/10/12 08:27 PM Share Posted 12/10/12 08:27 PM Hi guys, just a quick question. My engine light came on and flashed in intervals after I took off from a set of lights, then stopped about 50 meters down the road. Any suggestions ? The owners manual says oil temp, what could cause this ? And it was a cool night. Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/ Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m 2d Posted 12/10/12 08:38 PM Share Posted 12/10/12 08:38 PM Have u got a xcal? Any codes come up? Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1308607 Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 18y 1m 8d Gender: Male Location: Adelaide Posted 12/10/12 09:08 PM Share Posted 12/10/12 09:08 PM Have you changed your exhaust lately? 2nd oxy sensor can play up and do that. Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1308617 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 14d Gender: Male Location: SE Melbourne Posted 12/10/12 09:37 PM Share Posted 12/10/12 09:37 PM I think oil temp/pressure will beep at you as well as light turning on. If it didn't beep it's prob something else Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1308628 Share on other sites More sharing options...
B&E XR6 Member 8 Member For: 12y 9m 22d Gender: Male Posted 12/10/12 10:45 PM Author Share Posted 12/10/12 10:45 PM Thanks guys, no I don't have an xcal. I was thinking I should see someone to see if there are any codes.Yeah probably 3 months ago I removed the huge cannon muffler and just fitted a straight through muffler. Also I had just put fuel in, it was 98 octane, do you think that might have something to do with it ? Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1308664 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m 2d Posted 12/10/12 10:50 PM Share Posted 12/10/12 10:50 PM Could be anything, get it scanned and should show a code to give u an idea of why the light came on. Car is stock yeh? Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1308666 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 14d Gender: Male Location: SE Melbourne Posted 12/10/12 10:52 PM Share Posted 12/10/12 10:52 PM Could be boost cut. Better get it checked out. anything after the cat technically shouldn't affect flow but you never know. Maybe your cat has high flowed itself. Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1308667 Share on other sites More sharing options...
B&E XR6 Member 8 Member For: 12y 9m 22d Gender: Male Posted 12/10/12 11:58 PM Author Share Posted 12/10/12 11:58 PM Yeah it's pretty much stock, just a bigger intercooler, k&n air filter and 3.5 inch exhaust from cat back. I will get it checked to be safe, thanks for the advice guys Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1308696 Share on other sites More sharing options...
bionic_oosty Donating Members 241 Member For: 13y 3m 23d Gender: Male Location: Sydney/Wollongong Posted 14/10/12 09:25 AM Share Posted 14/10/12 09:25 AM Engine/Mil light is a fussy b!tch.. Mine came on the other week after I put a better cooler on with bigger piping. The oxy sensor didn't appreciate the car running at lower temps after that and the retune last week adjusted those sensor settings and haven't seen the light since!I've been in the exact same situation as you, but you will be guessing what it MIGHT be all day long until you get a tuner to sort it out 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1309176 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 18d Gender: Male Location: Christchurch, New Zealand Posted 14/10/12 09:41 AM Share Posted 14/10/12 09:41 AM Was it definitely your engine light, not a traction light flashing at you. (just asking since you stated it happened when taking off from lights.) Link to comment https://www.fordxr6turbo.com/forum/topic/82362-engine-light/#findComment-1309179 Share on other sites More sharing options...
