Spyder Member 7 Member For: 12y 8m 3d Posted 10/10/12 08:50 AM Share Posted 10/10/12 08:50 AM Hi all I have a 07 bf turbo ute with 130,000 k owned since New and looking at cheapest way to get to 400kw It has towed a 750kg trailer For 100,000km maybe more runs like a Dream Totally stock ATM Any info appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/ Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 8m 16d Gender: Male Posted 10/10/12 09:21 AM Share Posted 10/10/12 09:21 AM Cheap and 400kw in the same sentence,, doesnt happen Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307601 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 6m 6d Gender: Male Location: CQ Posted 10/10/12 09:36 AM Share Posted 10/10/12 09:36 AM Have a look through the 400+kw section and see what others have done mate... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307609 Share on other sites More sharing options...
6auto Member 6 Member For: 12y 9m 20d Gender: Male Location: QLD Posted 10/10/12 09:39 AM Share Posted 10/10/12 09:39 AM 400kw at the wheels or engine big difference Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307612 Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 14y 8m 25d Posted 10/10/12 09:43 AM Share Posted 10/10/12 09:43 AM (edited) spend cheap get cheap results, spend smart, get smart results. Set a budget triple it then you have a workable figure.Not trying to discourage you but I have only just finished my 400kw build (engine only) and I am starting to have to repair/rebuild other things down the line. Seriously sit down and figure out how much you can afford to spend divide it by 3 and use that as the budget for your build, cause it always blows out, no matter how good you are at money management.Injectors, cooler, fuel system, intake, exhaust, valve springs, gearbox, clutch, diff, turbo. Or as Ralph says just throw a new diff bush in it.... If you are handy with tools you can save money on labour so long as you do it properly. If you are literally going to do cheque book racing then add labour to your build and it will add up, plus tuning. If you want my opinion, don't do it if its your daily driver unless you are prepared for the repair and maintenance regime that comes with owning a car with that much power.Just my 2c Edited 10/10/12 09:44 AM by unclewal Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307613 Share on other sites More sharing options...
Spyder Member 7 Member For: 12y 8m 3d Posted 10/10/12 09:50 AM Author Share Posted 10/10/12 09:50 AM Lol yea I figure it won't be cheap but I'm really Just wanting to know what needs to be doneAnd what parts and where to buy as some places Can be deerer than others So far on the shopping list is bigger injectors size? Bigger intercooler Upgraded turbo bigger? Or modified? Cat back exaust my friend owns a ex shop he will do this Cold air intake Nizpro valve springs Over boost valve Bigger plenum ? I have a walbro 255lph hp pump allready from my 1uzfe Hilux will this be capable of 400kwI also have already bought a x3 flash tuner from intune So what else do I need to add to the list ? Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307620 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 10m 17d Gender: Male Posted 10/10/12 09:51 AM Share Posted 10/10/12 09:51 AM I did 400kw for about 10k in 3 stages, had I done it all in one hit prob wouldve cost 2k less and that's fitting everything bar valve springs myself Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307621 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 10m 17d Gender: Male Posted 10/10/12 09:53 AM Share Posted 10/10/12 09:53 AM (edited) Oh theres that name again! Hope theres no tunes loaded into it Edited 10/10/12 09:53 AM by bionicxr6t05 1 Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307622 Share on other sites More sharing options...
Spyder Member 7 Member For: 12y 8m 3d Posted 10/10/12 09:57 AM Author Share Posted 10/10/12 09:57 AM 400kw at the fly am able to do all work/labour just after parts Is my daily driver but my Hilux project is just about finished for now so I will drive the yotaOut of the shed and drive the ford in Tried searching first but I probably was looking in the wrong spot I'll keep lookingThanks Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307624 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 10m 17d Gender: Male Posted 10/10/12 10:03 AM Share Posted 10/10/12 10:03 AM (edited) 400kw at the fly would be about 300kw at the wheels?? Doable for 2grand with a cheap cooler, intank pump, 42lb injectors and high flow cat Edited 10/10/12 10:03 AM by bionicxr6t05 Link to comment https://www.fordxr6turbo.com/forum/topic/82330-400kw-bf-xr6-turbo/#findComment-1307628 Share on other sites More sharing options...
