bionic_oosty Donating Members 241 Member For: 13y 14d Gender: Male Location: Sydney/Wollongong Posted 10/10/12 11:33 AM Author Share Posted 10/10/12 11:33 AM IH8TOADS - Thanks mate.Which part do you think is going to give way or am I missing when it comes to mods.. Like do you mean it needs a surge tank (which I will now do when I get the chance) or something else others haven't mentioned?I'm leaning towards it actually having the upgraded BF II internals even though it's an early 06 model. The valve springs have been spot on perfect for nearly a year now running over 300rwkw. So it should have the rods also Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 6m 19d Gender: Male Location: OZ Posted 10/10/12 11:42 AM Share Posted 10/10/12 11:42 AM There's heaps of info throughout the forum, have a good look around and see what direction the community generally takes :-)The stronger rods would be a bonus but I honestly believe quality hardware mods like a big exhaust/cat, aftermarket plenum, surge tank etc go a long way and allow power to be made easier and safer....but nothing is safe! 1 Link to comment Share on other sites More sharing options...
wilba Member 828 Member For: 16y 2m 25d Gender: Male Posted 10/10/12 09:51 PM Share Posted 10/10/12 09:51 PM And jd custom make a surge tank cheaper them both listed above . I have one and have had no truble with it Link to comment Share on other sites More sharing options...
bionic_oosty Donating Members 241 Member For: 13y 14d Gender: Male Location: Sydney/Wollongong Posted 11/10/12 12:33 AM Author Share Posted 11/10/12 12:33 AM Can't find alot of info on JD Custom using google.. Would any surge tank (not custom made for an xr6t) be fine if you can bolt it up?? Coz there are some cheap 2L staino tanks with 044 brackets out there. I could have a tank, bracket and genuine 044 pump for under $300 if so...Or does it have to be the correct shape mounting plate to make it fit where it needs to go? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 4d Gender: Male Location: Perth Posted 11/10/12 12:44 AM Share Posted 11/10/12 12:44 AM That's what I did, I contacted one the ebay sellers and asked if they did custom tanks, which they did, Got mine made @ 2ltr capacity with dual -10 outlets for dual pumps and E85. Speed flow sell the fittings you need to connect to the stock line, brackets are very easy to make. 1 Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 1m 11d Gender: Male Posted 11/10/12 02:08 AM Share Posted 11/10/12 02:08 AM Here is one I did myself in my KE20 corolla. Tiny surge tank, but it was initially for an NA 100kw twinky motor. Adam Niesch tuned it once it was turbo'd.The pic might be a bit clearer in terms of what you are trying to achieve with a surge tank. The aim is to fill a container with fuel which, by its shape, will always allow fuel at the inlet of the pump. you fill it with the first pump, have the return from the rail also filling the tank, have an overflow back to the main tank, and one outlet for the main pump to the rail (in this case the hektik VL turbo pump)don't worry I have my flame suit on, let me have it but go easy I was an apprentice at the time so $$ was tight. plus I'd never really mucked around with cars before, let alone engine conversions. 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 4d Gender: Male Location: Perth Posted 11/10/12 02:11 AM Share Posted 11/10/12 02:11 AM needs moar fuel filters 2 Link to comment Share on other sites More sharing options...
bionic_oosty Donating Members 241 Member For: 13y 14d Gender: Male Location: Sydney/Wollongong Posted 11/10/12 07:19 AM Author Share Posted 11/10/12 07:19 AM Cheers for explaining that 'suck squeeze' makes good sense mate!!Thumbs up for your 1st time effort also. Link to comment Share on other sites More sharing options...
Weaponxr Donating Members 624 Member For: 14y 1m 16d Gender: Male Location: Melbourne Posted 12/10/12 12:47 AM Share Posted 12/10/12 12:47 AM +1 for the Surge tank, I myself have a Process West Surge tank and Bosch 044 pump. The car now feels stronger right through the rev range although its making similar power to before I had the surge tank fitted and retune.Something you may also want to keep an eye on is your Valve springs. If you give it a boot ful and then it idles a little lumpy afterwards it could be a sign that the valve springs may be a little soft Link to comment Share on other sites More sharing options...
bionic_oosty Donating Members 241 Member For: 13y 14d Gender: Male Location: Sydney/Wollongong Posted 16/10/12 02:15 PM Author Share Posted 16/10/12 02:15 PM (edited) Real happy with the car but as it needs a retune anyway after I do surge tank, I've decided to relocate battery, add 4" intake, surge044 and send it back to Jem for a 6Boost manifold and retune. Was also keen on the gtx3582r but my tuner said the standard turbo has more in it with the 6boost coming. And that he would personally go with a GT4094 if I were to upgrade. PS: Damn the power bug! Edited 16/10/12 02:19 PM by bionic_oosty Link to comment Share on other sites More sharing options...
