Rapidsystems Intake Cover
jonn
  • Member For: 15y 10m 30d
just wondering if anyone that has made a intake box for the battery side has any dimensions to cut so I can make my own?
  • Member For: 14y 3m 29d
Haven't made one myself, but it should be fairly simple. FYI that pic is not the rapid intake and is a little more difficult due to the bend in the side piece which is not needed.
Take the battery out. measure the distance from the fuse box to about the headlight and also the depth, cut a square/rectangular piece which should sit straight in there. You could mock up the top piece with some paper if you like then cut the metal to suit. So pretty much, you only need two pieces of metal. Don't forget mounting points for screws.
Good luck if you give it a go!
edit: check this link and you will see its just a couple of pieces
Edited by Goliath
thanks mate, yeh I wouldnt mind getting the 4" intake kit from the website but dont know how it will fit with the HDI cooler kit.
gave it a shot with some plastic acrylic
  • Like 2
