geekatrons Member 60 Member For: 12y 6m 10d Posted 06/10/12 11:44 AM Share Posted 06/10/12 11:44 AM Hello AllHas been a while- I have spent a bit of time in the BA and getting things done. Recently got new rear shocks and diff bush done. I am at wits end as to what is going on with the old girl, when I start the car hot or cold and I get to the first set of lights and wait there the car feels like it wants to surge forward- the revs drop and it is at a stage where I think it may stall- gets to around 500 RPM. Once it gets going seems ok. I still have a shudder I am thinking that it might be buckled wheels- I have tried to put them at the back but I don't know what options I have other than buying new wheels and hoping this is the problem. Even at idle I feel a slight shudder through the wheel- would a tailshaft balance cause a shudder at idle? In drive or in neutral still has the same feel???Please help p.s the shudder doesn't matter if I am doing 20Kph or 110kph still the same feel through the wheel- the passenger seat I can see shudder when driving also??? really bloody annoying Link to comment Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 12y 11m 22d Gender: Male Posted 06/10/12 02:49 PM Share Posted 06/10/12 02:49 PM Possibly an o2 sensor for the revs issue. Mine used to do a similar thing. Link to comment Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 17y 7m 4d Gender: Male Location: Adelaide Posted 06/10/12 06:58 PM Share Posted 06/10/12 06:58 PM Check the prop shaft angle. Changing diff bushes can mean shimming is required. Non stock bushes? Wot colour r they? Link to comment Share on other sites More sharing options...
geekatrons Member 60 Member For: 12y 6m 10d Posted 06/10/12 09:48 PM Author Share Posted 06/10/12 09:48 PM Hello the diff bushes are red. Nolothane from pedders- was shuddering before this. Also in regards to the o2 sensor I have already got a new one- been in for about 2 months.? not sure if this is the problem? unless is a faulty one? it was a different look to the original but assured that it is for the XR6T.??I have a mate who works for a diff place I might take the car to him and get him to have a look. Link to comment Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 17y 7m 4d Gender: Male Location: Adelaide Posted 06/10/12 10:49 PM Share Posted 06/10/12 10:49 PM Not sure if you are saying it's the same even at faster speeds? Tailshaft/propshaft will still turn in nuetral. Link to comment Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 17y 7m 4d Gender: Male Location: Adelaide Posted 06/10/12 10:53 PM Share Posted 06/10/12 10:53 PM (edited) Dodgy diff should make a noise as well. Tailshaft/propshaft will still turn when rolling in nuetral. When you say there is a shudder at idle do you mean when rolling? Tailshaft and diff will not cause a shudder when stationary obviously. Edited 06/10/12 10:54 PM by davidald Link to comment Share on other sites More sharing options...
geekatrons Member 60 Member For: 12y 6m 10d Posted 07/10/12 10:59 AM Author Share Posted 07/10/12 10:59 AM hello when I stated in neutral I mean stationary also. I noticed something today, started the car up from cold and the when I turned the steering wheel slightly the vibration through the wheel was really bad- I went full lock from left to right and when turning right it squeeked a little. Could this be an issue with the power steering? As far as the speed goes it is no better or worse at speed- The diff is not noisy- (well typical noise- not crazy. I am at wits end at the moment. Link to comment Share on other sites More sharing options...
Falky100 Donating Members 305 Member For: 12y 11m 22d Gender: Male Posted 07/10/12 02:37 PM Share Posted 07/10/12 02:37 PM Unfortunately you need to get genuine ford o2 sensors. I had the same issue, my mechanic put cheap non genuine ones in and dis not fix the problem. I put genuine ones in and instant fix. As for the steering shuddering at stationary. Mine has done it every now and then. But not often, would be interesting to find out what it is though. Link to comment Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 17y 7m 4d Gender: Male Location: Adelaide Posted 07/10/12 07:47 PM Share Posted 07/10/12 07:47 PM If you have had the wheels off the ground as in on a hoist or the front jacked up and the wheels have turned (left or right) at all you will get air in the PS system. Purges itself eventually. Link to comment Share on other sites More sharing options...
perendale express Member 6 Member For: 12y 9m 23d Posted 09/10/12 09:32 AM Share Posted 09/10/12 09:32 AM Sort the o2 sensor out, mine used to try and stall when I came down to an idle. And every now and then itd run very rough, gear stick would be rattling around violently uncontrolable. Everythin came right when the o2 sensor was cleaned Link to comment Share on other sites More sharing options...
