  • Member For: 17y 6m 26d
It looked killer in the stills you put up after the repaint. Get her fixed nice and strong so we can see it on a drive!
  • Member For: 13y 6m 23d
Problem Solvered everybody..!!!!
Big thanks to Luke for the help and use of his TIG.
Ended up using 3 x 1/2" washers.
Tacking them together to make the overall thickness match the old plastic piece. Then notching out a slot in the washers and welding in the pushrod of the Mc....
Works a treat and no doubt stronger then ever.
Thanks for all the input fellas..saved me hundreds !!$$!!
  • 1 year later...
  • Member For: 12y 16d
Sorry to dig up an old thread guys, but I had this exact problem recently and did what you did by making up my own set up and welding it together. I have found now though that the take up point on the clutch is ridiculously high! Is there any way to adjust the pedal down to make it easier to drive? Its really weird trying to drive it now :/
  • Dropping a turd
  • Member For: 17y 7m 24d
No adjustment. You have obviously changed the installed length.
Measure and modify.
  • Forged Member
  • Member For: 18y 4m 12d
As above, you'll have to re-do it...
Also, we prefer you to dig up an old thread, better than starting a new one for a topic that has already been started!
  • 2 months later...
  • Member For: 14y 11m 4d
Clutch Pedal
Hi all,
Thought I'd keep this these going rather than starting a new one.
Clutch pedal just went on a 07 BF XR6T II, exact same thing to post #1.
Noticed a little splat of oil on foot when clutch pedal went straight to the floor while taking off in first gear (clutch pedal went straight to the floor).
Noticed the black plastic broken (will take pictures for reference) on the floor but my concern is the oil.
Is it just replace the black plastic (where to get it from, ford, Repco, Bursons?) or could it be more with cylinder to be replaced???
Thoughts?
Edited by nick d
  • Member For: 15y 5m 2d
Malwood normally do the clutch master cylinder for an alright price.
^^^cheers for that.
Still doing my head about the little spill of oil.
This is a picture of the plastic eye that connects to the clutch pedal:-
So after reading above will have to change master cylinder when I replace the eye?
Has anyone one used this:- http://www.ebay.com.au/itm/Ford-BA-BF-Clutch-Clevis-/281355361908?pt=AU_Car_Parts_Accessories&hash=item4182161e74&_uhb=1
Or should I stick to the original plastic ford eye part ?
Edited by nick d
