Fg Struggling To Make Boost..
pac23
  • Member For: 14y 5m 9d
Nizpro cooler only comes in one size.. Big. Definitely 3inch cold side. Initially I was concerned about the size but after come research I was confident it would be ok. Throttle response is bordering ridiculous down low. Feels like a big block off idle.
And I suppose you can say IVe future mod proofed it.
Smaller turbo is more than capable of filling the cooler. We musnt forget the 4ltr is quite large in the turbo world. They pump alot of air..
  • Member For: 12y 9m 2d
I think I will pop into my local exhaust shop and get the cat checked out.
Is the flapper upgrade worth doing. I can get the housing modded for $350 and I already have a 12psi actuator. Do you notice much difference with the bigger flapper?
Thanks for all the replies..
Not after huge boost as I am not doing the exhaust. Only the cat and possibly 4inxh dump. So 15 in the mid tapering to 13 will be more the. Sufficient but will the standard actuator be enough for this or should I refit the 12psi and should I do the flapper??
Thanks
He recommend exhaust doesn't sound right. So maybe the cat. I was just considering whether it is a worthy mod before taking it back to him. Can get the flapper for only $350. And have an actuator. Just need to fit it...
