  • Member For: 12y 6m 25d
Hi all,
I was wondering if I could use an external amp connected through high level input from the factory sub amp input (see attached image). The inputs I was looking at bridging into are in+ and in- . Also the amp I will be using is a 2 channel and the high level input has 4 wires (I guess two for each channel) would I only need to connect one channel?
Thanks,
post-53308-0-34839900-1348891058_thumb.j
