Fg Sedan Rear Camber Adjustment
Bellato
  • Forged Member
  • Member For: 17y 11m 22d
Stop stressing out about it!
Your car isn't going to spontaneously combust just because you have incorrect camber settings on the rear. The toe adjustment will be enough to get the car steering straight and then you can look at getting some adjustable arms later on down the track.
  • Replies 29
  • Member For: 14y 3m 10d
I just wanna get things right the first time Senna that's why im stressing.
I went to Ford to find out about these adjusting bolts for the outer bolt on the control arm and they gave me two model numbers.
BAJK751BKT (RHS) and BAJK751CKT (LHS). They're $70 each so not cheap but cheaper than replacing tyres because they're scrubbing out
Can anyone confirm this is what I'm after? Is it right that the bolt and washers can just slot into the existing bush and just be turned for camber adjustment?
  • Forged Member
The last time we did the conversion for a customer (a member here with username tpinto) we had to change the hubs and the arms, The hub was different because there was a slot in it to allow movement rather than just a round hole for the bolt to go through.
I got my wheel alignment and turns out the right rear was spot on zero camber but the left was 1 degree neg. Doesn't make any sense, the only thing I can think of is that the offset bush in the left side wasn't put perfectly offset, just wondering whether the bush would rotate at all to the outer most point because with the car bouncing up and down would eventually rotate the bush?
If not I might have to pull the right side back out and put it in a bit different to put a little bit of neg camber to match the left.
At least it looks like I don't need adjustable control arms
  • 7 months later...
  • Member For: 11y 9m 21d
Hate to drag up an old topic but my ba has the adjustable rear arms and also came factory with tow pack. Maybe they were installed on cars with tow pack to adjust for the weight on the rear? Just looking at lowering my fg and its a real pain cos my suspension guy wont drop the cradle out to do the control arms. Is there a step by step somewhere on doinf these in an fg
  • 3 weeks later...
  • Member For: 17y 2m 24d
Going to get my rear Camber checked on my G6E to see if it has adjustable rear Camber as it's starting to eat the insides of the rear tyres and had a vibration since lowering it, also have noticed in reverse when going slow it has a very slight thud thud thud noise like driveshaft...
