Bellato Donating Members 2,713 Member For: 14y 8m 9d Posted 26/09/12 06:34 AM Share Posted 26/09/12 06:34 AM Hey guys I put ssssl springs in the rear of my FG the other day and put in offset bushes to correct the camber but had to just guess how much to correct as you have to do it with the wheels off so I put them to max.I have a wheel alignment on friday and when I spoke to the guys today they said most fg's have a camber adjusting bolt on the upper control arm at the outer joint but apparently mine doesn't?Is there any form of camber adjustment for the rear of these cars? It looks like there is some sort of adjustment in the lower control arms (?? not sure if that's what they're called, the arms that the spring sits on) at the two bushes in the middle under the diff?Need help before friday!!Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 5d Gender: Male Location: Perth Posted 26/09/12 06:47 AM Share Posted 26/09/12 06:47 AM adjustment on the lower arm is the toe angle, camber is adjusted with the top arm outer bolt. It has a cam plate set up. IIRC not all FG's had this.Can you take a pic of the top bolt through your wheels? Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300517 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 9d Posted 26/09/12 07:06 AM Author Share Posted 26/09/12 07:06 AM Apparently mine doesn't have it? How much to have it changed to an adjustable bolt Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300527 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 5d Gender: Male Location: Perth Posted 26/09/12 07:07 AM Share Posted 26/09/12 07:07 AM Both rear uprights as the top bolt hole is slotted to allow for the camber adjustment Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300528 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 9d Posted 26/09/12 07:11 AM Author Share Posted 26/09/12 07:11 AM So should be all good then? Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300532 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 21d Gender: Male Location: SW Sydney Posted 26/09/12 07:12 AM Share Posted 26/09/12 07:12 AM Yes it was only the V8 equipped FGs that came with this adjustment from the factory...don't ask me why having a V8 makes it more important to adjust camber.... Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300533 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 9d Posted 26/09/12 07:19 AM Author Share Posted 26/09/12 07:19 AM So how do you guys adjust camber in the rear of the FG's Senna? And stupid Ford one of the many smart things they do Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300538 Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 16y 26d Gender: Male Location: Brisbane Posted 26/09/12 08:21 AM Share Posted 26/09/12 08:21 AM you can get fully adjustable top arms from Nolathane, I've got a set in mine. Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300574 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 5d Gender: Male Location: Perth Posted 26/09/12 08:35 AM Share Posted 26/09/12 08:35 AM You can also get them from P@ @ WHS Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300578 Share on other sites More sharing options...
wa g6et Member 657 Member For: 14y 25d Gender: Male Location: Perth NOR Posted 26/09/12 11:35 AM Share Posted 26/09/12 11:35 AM I have Kmac eccentric bushes fitted to the rear inner upper arms. Allows about 1 deg camber adjustment.BA XRs had an adjustment on the outer end of the upper arm.Didn't know V8 FGs had this too, I thought no BF or FG had rear camber adjustment. Link to comment https://www.fordxr6turbo.com/forum/topic/82093-fg-sedan-rear-camber-adjustment/#findComment-1300684 Share on other sites More sharing options...
