GTEXXED Banned Banned 910 Member For: 12y 7m 1d Gender: Male Posted 26/09/12 05:06 AM Share Posted 26/09/12 05:06 AM (edited) Howdy guys,got a substantial leak somewhere and may have tracked it down.I have had to clean from the fuel tank to the front of motor,oil is only on passenger side.I have cleaned her all up and found that the lower intake manifold bolts(ones to head)seem to be leaking.I had her running for 5 minutes after cleaning everywhere and after 5 minutes of shutdown some oil appears around the head of the bolt seeping through lower manifold gasket.Could oil somehow be forced under boost into the manifold and then leak through my apparently ever so slightly leaking manifold gasket,idle is still fine.I only run a catch can on the rocker cover vent,PCV valve is as from the factory.PS:tried to donate but wont accept Visa,is this correct?Cheers for all responses! Edited 26/09/12 05:07 AM by GTEXXED Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 1m 3d Gender: Male Posted 26/09/12 06:07 AM Share Posted 26/09/12 06:07 AM just donate to my account mate haha. with the factory pcv u would not believe how much oil gets into the intake mani. and if the mani bolts are loose, could be getting through there. how much oil though - the cars runs sweet yeah ?? see if those bolts are loose. Link to comment Share on other sites More sharing options...
GTEXXED Banned Banned 910 Member For: 12y 7m 1d Gender: Male Posted 26/09/12 06:37 AM Author Share Posted 26/09/12 06:37 AM Ok,bit of a update.The back of the firewall is splattered with oil and the fuel rail/injectors.What ever it is must only happen under boost as its not leaking stationary in my driveway.can a rear main make the oil go that high in the engine bay,even the base of throttle body has some splatters?I dont think its the manifold leaking the oil but I know she is leaking air as brown air stains are around the lower manifold port holes.having the oil get as far back as the fuel tank cover makes me concerned though,maybe the trip to mallala at highway speed pushed the leak from the front all the way back. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 27d Gender: Male Location: Victoria Posted 26/09/12 06:51 AM Share Posted 26/09/12 06:51 AM Have you had a look around the oil pressure switch area for leaks?You really need to run it while it's on a hoist to find where it's coming from. Link to comment Share on other sites More sharing options...
GTEXXED Banned Banned 910 Member For: 12y 7m 1d Gender: Male Posted 26/09/12 06:59 AM Author Share Posted 26/09/12 06:59 AM Yep,all pressure switches are fine and the oil feed area is dry also.looks like a hoist job,honestly never seen oil go this far back on a car before. Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 2m 5d Gender: Male Posted 26/09/12 07:56 AM Share Posted 26/09/12 07:56 AM Have checked your catch can setup on the breather is not blocked somehow? Link to comment Share on other sites More sharing options...
